Question about Dynex DX-L32-10A 32" LCD HDTV
There was a power surge that wiped out a few applaances and my dx-L32-10A will not come on. Help.
  • 11,361 Answers
Check the main clipped-on AC fuse F1 (5A 250V) located at the bottom left of the picture here: http://assets.shopjimmy.com/media/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj6kt0012010.jpg
If new power supply is needed, it is only $60.
http://www.shopjimmy.com/dynex-6kt0012010-power-supply.htm
If it is blackened in side the fuse, that means it was exposed to heavily shorted circuits. I would inspect the power supply real close for any blown parts before installing new fuse.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find
Posted on Mar 21, 2011
Testimonial: "Took the back off and found a blown fuse-Cost less than $2.00 to fix. Thanks bunches. Termite"
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both or a fuse in the power supply section went.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
The fuses on the most part will be surface mount and a bit harder to spot.
They will be white rectangular boxes (marked F1, F2 etc on the PC board) or green and flat (same type markings) or they will be 0 ohm resistors (marked R01, R235 or such markingson the board, but will have a ) on their surface if you look at them under magnification) and be flat and black. These components should all read 0 ohms.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors or fuses will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating). Match the fuses with the markings on them (ie- if it says 10V 3A, replace it with a 10 volt 3 amp fuse)
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, the capacitor issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 19, 2011
My stereo just quit on me there was bad weather but it was on one of those power surge cords it is a pioneer stereo fm-am digital synthesizer tuner
If it was plugged into a surge protector, check the surge protector warranty. There are A LOT of surge protectors that will cover damage to items plugged into them through their warranty system. I've had full home computers and TV's replaced by surge protector companies to avoid having a hit to homeowners insurance.
Aug 16, 2016 | Pioneer Audio Players & Recorders
My Dynex TV wont power up. After a recent power outage,my flat screen never powered back up.
try uplugging it both from the tv and the outlet. you may need a new power cable. Was it connected directly or through a surge protector?
Jul 25, 2011 | Dynex DX-LCD32-09 LCD TV
During thunderstorm tv went off and wont power back on
It's very likely that your TV experienced a power surge and it fried the components within the television. I would recommend buying surge strips (can find these for $20 or so, or more depending on its features) from an electronics store and have all your nice electronics plugged into them. TV, computer, sound system, etc. Power surges are a common way of losing electronics. I'm not saying the TV is completely broken, I would need more information/hands on, but I have a feeling you're going to be buying a new one after this.
Jul 24, 2011 | Dynex DX-LCD32-09 LCD TV
Smt 190 dx won't turn on after power outage
Processor could have some garbage in it to to the power surge and if you unplug the set from the wall for 40Min., it will rest back to normal.
Feb 11, 2011 | Samsung SMT-190 19" Flat Panel TFT LCD...
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
Blown fuse everytime it powers on
yes right there is a short circuit in power supply if you are non technical then replace the power supply if you are technical then open the power supply and check the 4diodes of bridge if faulty replace it again check transistor attatched to heat sink if faulty repalce it
Feb 28, 2010 | Pyramid (PS36KX) 600-Watt Power Supply
Sound without picture unit did not go thru auto set up input will not display
returned defective unit to the store after talking to them and determining the menu would not display.
Jan 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Dynex DX 402 Router
Check for power surge or any other related proplem. Electronic item strat malfunction, if it does not get proper current.
you connect the router power supply to UPS and check for happy ending.
Apr 19, 2008 | Dynex DX-E401 Router
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
Dynex DX-L32-10A 32" LCD HDTV Logo
546 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
