Question about Sharp CD-SW300 Shelf System
System not powering on. timer light blinks - Sharp CD-SW300 Shelf System
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
Wall timer makes lights blink
Timer is wired incorrectly.
Single pole wiring does not use the red wire. Red wire is capped off.
Copy following link to see specific wiring illustrations for ST01C timer:
http://waterheatertimer.org/ST01C-program.html#wire
Related but not same problem:
In some 3-way wiring installations, if the power goes out, or if the bulb burns out, the timer can click. The lights do not blink because power is out or bulb is bad. Simply flip the 3-way switch to stop clicking sound. Then change light bulb, or wait for power to resume.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 04, 2012 | Intermatic Inc. ST01C Digital In-Wall...
My wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Nov 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Tv won't power on
I trashed the set and bought a new one.
Jul 02, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Timer light blinking
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Nov 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Sharp CD-SW300 Shelf System Logo
49 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
