Question about Champion International Garden
My CPW 2000 will not work! it switches on but no pressure, it has been in the shed all winter!
3 Suggested Answers
  • 37 Answers
SOURCE: What do I have to do to winterize my pressure washer?
Gasoline goes bad after sitting for an extended period of time.
Old school people would drain the gas out of the tank but found this lead to rust forming in the tank.
Now it is best to fill the tank with high octane gas and use a winterizing fuel additive to prevent problems.
Also remove any water from the hoses.
In the spring replace the gas and change the oil and you should be good, changing the spark plug would also be beneficial.
Posted on Oct 11, 2009
Testimonial: "This was helpful. My biggest concern was the water manifold."
  • 107 Answers
SOURCE: . it was in the
I believe it had water in it and it froze. My did this and I had to open it and replace a plastic
tube which cracked when the water froze. Very important to completely drain or place in a place where it won't freeze.
Posted on Apr 22, 2011
Housing on bottom has developed cracks and water leaks out. What caused this steel housing to crack??
In winter when it has frozen and the pressure washer was in the shed you can assume that this may have been a cause.
Nov 07, 2015 | Garden
Manual for champion cpw 1750 pressure washer
Go to manufacture web site and search model for download.
Oct 03, 2014 | Champion International Garden
My winter/ power button on my 2000 passport is jamed and it is ingaged in winter mode how do I fix that or were do I begin?
WINDOW CONTROL SWITCH BUTTON WORN MORE LIKELY WHEN BUTTON STICKING IT WILL A TIME SWITCH WILL STOP WORKING.
Oct 08, 2011 | 2000 Honda Passport
Model CPW 1800 2 lance guns have developed leaks when pumping against dead end. Do these washesr have a pressure relief valve . Can this be replaced?
Byronj25, you can get the internal part that has most likely failed here. http://www.sparesgiant.com/p-4993-annovi-reverberi-210-gun-valve-kit-with-o-s-2291.aspx. You may want to dismantle it though and check that the black elbow tube has not failed also, as that part is obsolete and so would require a full new Lance. New Lance link http://www.sparesgiant.com/p-5002-champion-cpw-yellow-hl2-annovi-reverberi-gun-large-bayonet-40409.aspx
May 21, 2011 | Annovi Reverberi Garden
. it was in the
Apr 22, 2011 | Garden
Have argos xtreme lawnmower 123cc petrol 3.5hp last used oct 2010 and stored in brick shed for winter. Will not restart april 2011. It has petrol and petrol switch is on. The choke is out for cold start...
Stale fuel is normally the cause for bad starting after the winter, fuel has a very short shelf life before it goes stale, drain the fuel tank and carb float bowl, refill with freash fuel and try again
Apr 05, 2011 | Garden
Well my yfz 450 sat in my shed over the winter so i drain the tank and clean the carb. Then i went to start it and it wouldnt fire up. I took it apart and check it for spark from the coil and didnt have...
the ignition cant fail from sitting, perhaps the kill switch has corrroded, always put a spark plug in and ground it to the head when checking for spark , also check with a new spark plug
May 15, 2010 | 2004 Yamaha YZ 450 F
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
Flat screen tv winter storage
HELLO
Your TV will be fine as long as it is kept at room temperature indoors and not inside a shed or similar outbuilding. Much warmer in a house, probably near freezing in a wooden shed.
Hope this helps you (:-)
Oct 17, 2009 | RCA L32HD31 32 in. LCD HDTV
What do I have to do to winterize my pressure washer? It will be in an unheated shed all winter.
Oct 10, 2009 | Northstar Pressure Washer 2800 PSI
Garden Logo
234 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
