Question about Canon imageRUNNER C6800 Copier
Tengo un problema con el adf de la canon irc6800 le e hecho un memory clear y luego de eso ya no me reconoce el adf el resto funciona bien, el adf reconoce la hoja pero al momento de hacer la copia sencillamente me marca papel atascado y al abrir y cerrar el adf el error de papel atascado persiste ,como lo puedo solucionar??
  • jeff heightchew
    jeff heightchew Mar 20, 2011
    wow, Spanish. That narrows down the number of people that can help you .My Spanish is weak but it appears you have a problem with your document feeder.
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Tengo problemas con lasbujias ya le compre segun las originales y no se hace bie los cambios y se ahoga y nose estabiliza bien el mtor tambien tengo problemas con se revoluciona mucho el motor y no...
cambia los cables de las bujias talvez tienes un cable q este aterrizando la corriente y te provoque la fatla de potencia al vehiculo ademas revisa que las bujias que le pusiste esten calibradas segun las especificaciones del vehiculo tambien eso puede repercutir el la vibracion del motor
Feb 24, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
Corto sircuito del fuse #20 del malibu 2004 de que es este fuse
In a 2004 Chevrolet Malibu, Fuse 20 is for the cigar lighter and auxiliary power outlets
Dec 30, 2012 | Cars & Trucks
Tengo una ford f150. 2005 cuando le pongo la palanca en la D para abansar y acelero no funciona se parina y derepente agarra. O cuando ago un stop en una luz roja cuando cambia a verde acelero y se patina....
Alacrana si tu troca le esta pasando eso ya tr recimiendo que compres una transmision usada o nueva ya ya los discos de adentro estan gastados si le metes arreglo que sea reparacion para la caja completa asi te vas a haorrar gastar aya ya ak en cada taller o mecanico a domicilio
Apr 16, 2012 | 2005 Ford F-150 Regular
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Tengo un problema con un cadillac deville pasa el aseite al anticonjelante se calienta y pierde mucha fuerza asta no kerer correr mas el mecanico dice poder correjir el problema cambiando los empakes pero...
el problema de aceite mescandose con el anty congelante es por lo regular empaques de cabeza pero en algunos casos puede ser solo empaques de manifool de admission o en terminos usuales diriamos empaques de la arana asegurese que el mecanico le de un precio en caso de que solo sean los empaques de arana por logica seria mucho mas varato que los de cavezas. el caso de la cantada a que se devio le faltava agua? o estava tirando talves bueno a menos que la transmission no trabajava bien antes de la primer calentada estaria en mal estado pero si trabajo bien antes no tendra ningun problema. espero este comentario le ayude para ahorrar algo de dinero y trabajo buena suerte, informeme de lo que acontesca y grasias.
Feb 23, 2011 | 1998 Cadillac Catera
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Problema en el ps2
Amigo, creo que solamente se dasabilita eso por el jumper, pero la pregunta es, el board sin teclado conectado funciona, o sea despierta, si es asi, conecta el teclado USB cuando la maquina este funcionando, con el sistema operativo (windows, linux, o el que sea) , si no arranca, puede ser problemas de memoria, prueba cambiarlas y me dices, un saludo Marlon de la Rosa
Feb 01, 2009 | AOpen MX4LS (91.88Q10.001) Motherboard
ACER ASPIRE 5100
que era lo que estabas haciendo cuando paro de trabajar? yo tengo el mismo problema con la mia, y creo que halgo esta malo con el BIOS.
Jun 15, 2008 | Acer Aspire 5100 Notebook
Canon imageRUNNER C6800 Copier Logo
112 people viewed this question
old marine
old marine
