Question about Philips Under-Cabinet Alarm Clock Radio with CD Player
Nothing works except the clock - Philips Under-Cabinet Alarm Clock Radio with CD Player
  • lkugath Mar 19, 2011
    I inserted a battery and now I can choose AM, FM or CD and see my preset stations. The CD eject button doesn't work. I still get no sound. The wall electrical outlets work fine.
    Thanks,
    LeAnn
    President:
  • 739 Answers
Hi..
Check the power into your radio unit, most likely a problem with your unit power (clock function, because it has a battery support to the watch)
and if your unit has the support of the batteries, the better you perform the test by inserting the battery to perform troubleshooting.
regards
Posted on Mar 19, 2011
  • HTS Sri Aman
    HTS Sri Aman Mar 19, 2011
    Ok,,
    If your unit is successful in this switch means that the problem of the entry power. most likely is at its problem of internal ac power. If you specialize in repairs of electronic equipment such as this, I suggest you change or perform tests on the internal ac power using ac power is 100% functional. If not, you should get an outside line experts to do the work because it requires expertise to perform these ac conversion. and if everything is finished, the results of the sound and the door of your cd player can be concluded.
    regards
Clock runs, no music played, nothing works, except it keeps time. what can I do to repair?
do you think we're all psychic enough to know what you're referring to?
Nov 23, 2017 | Audio Players & Recorders
Ever since I took out my battery and put it back in the radio hasn't work. None of the buttons work except the volume when a cd is in but nothing else works. It's a pioneer radio deh p7500mp.
Looks like it's the same thing that happens when I remove the power cord from my home hi-fi system... when I reconnect it it goes crazy on display mode till I reset the clock. In your case, the obvious difference is that it may have lost the clock time and memory presets.. see if retiming the clock and reprograming the tunner presets does the trick.. also check the memory fuse...usually the one on a pink wire.
Sep 28, 2012 | Cars & Trucks
Oven element blew.no top burners working.replaced oven element.nothing works except clock and oven light
Check your main fuses, it sounds like you are only operating on 120 volts.One of them is blown.Or if on breakers, switch stove breaker off then on again.
Mar 06, 2011 | Kenmore Kitchen Ranges
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
LED's in clock work only occasionally
It is very common for those to burn out. Nothing you can do to fix it except replace it.
Dec 11, 2009 | 1995 Nissan Maxima
Power switch no longer works nothing works except
Please contact the below for service.
Online: customerservice@sharperimageonline.com
Phone: 1-877-714-7444 8:00 AM - 8:00 PM EST Monday - Friday
Oct 30, 2009 | Sharper Image Travel Soother 20 Clock...
Jenn-Air JES9900BAB Electric downdraft range with convection oven
sounds like the power outtage fried the clock. unfortunately, none of today's ovens come with a UPS (uninterruptible power supply), sort of like a power box for your computer. if he power goes out, it'll fry the electronics, including the clock.
have a technician come out and test the clock to see if there is power going to it and what voltage is coming out of it. i would suggest replacing the clock.
Apr 05, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Philips Under-Cabinet Alarm Clock Radio with CD Player Logo
214 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
