Question about GE WSXH208A Front Load Washer
How do I remove the selector knob on washer
I have a GE WSXH208A front loading washer and need to remove the front control panel to replace a part behind it. But I could not get the selector knob to come off.
    Novelist:
  • 116 Answers
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
Washer would not drian nor spin
no the solution is that the drain pump is dead and needs to be replaced open the front panel of the front loader and locate the filter and clean and also remove!!
Aug 20, 2010 | GE WSXH208A Front Load Washer
Ge front load washer do not drain
Disconnect power to machine. Remove bottom front panel by removing one screw from each lower corner of panel. Have a few old towels ready to catch water, and remove clamp at pump inlet. Fish out all the coins or other objects from the rubber boot pump inlet. Reassemble and test with the panel off first. If all OK and no leaks, replace panel.
Jun 18, 2010 | GE WSXH208A Front Load Washer
When I wash towels they are soak when the cycle is done. How do I get the washer to properly spin the excess water our of the towels?
I have a GE front loader and this problem drove me nuts after spending $$$$ and having this problem only after 2 years of operations! Please check the filter screen. Remove the screws that hold the front panel to the body. There will be water coming out, so have some towels and a pan to collect. Once the panel is removed, there is a knob for the filter screen which needs to be turned to remove. Have your pan ready because it will leak. You can clean the screen by hand removing the gunk (keep the money for your efforts, however :)) Replace the filter, turn to tighten, replace the front panel and screws and run the washer through a short cycle to check out everything and make certain there are no leaks before you walk away. Good Luck!
Mar 07, 2010 | GE WSXH208A Front Load Washer
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Ge front load washer won't spin
replace the drain pump.and 2 remove the control panel u need 2 remove the 3 screws from top cover from the back
Oct 31, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
525 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
