Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Hi. have F& Paykel E440T. Six years old, started beeping two weeks ago and tripping RCD in the last few days.Freezer fan is working but runs now when freezer door is open.Turned fridge off last night and today water tray above compressor was nearly full,so must have ice blockage in drain from freezer.Now when fridge is turned on fridge compressor and freezer fan run non stop (with door open) and fridge green light flahes and no temperature indication on temperaure setting.Also is tripping out RCD trip switch again,the defrost heater has 17ohms at ohms by 10 sclae. thanks David J
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
mrfixit3667
  • 262 Answers
SOURCE: Where can I get a freezer pocket for a Fisher
I would try here first :)
http://www.fisherpaykel.com/customercare/parts/
There is a Phone Number here also :)
Posted on Oct 06, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer working fine, fridge not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
  • 5370 Answers
SOURCE: We are babysitting our friend's Fisher and Paykel
Does it trips the house power directly you turn the refrigerator ON.If this is the case then its either fridge board problem,the board is getting short or the voltage of the socket has to be checked,to which the power cord of refrigerator is getting connected. --------------- But as you mentioned the beeping problem.This beeping is problem with most of the fisher and paykel model refrigerators.This problem is noticed due to the faulty fan in the fridge as well as freezer section.--------If the fan is getting short then it can cause the problem.--------Also the defrost element has to be checked.If its getting short then it will shut of the refrigerator.-------- The parts are available only from F& P service center. For service or repair of your Fisher & Paykel appliance, please call 1300 650 590 to arrange for a local service technician.Click this link directly for F& P SERVICE CENTER LOCATION:-- http://www.fisherpaykel.com/customercare/servicelocator/ ------------- This should help.Thanks.Helpmech.
Posted on Feb 28, 2011
diodeic
  • 1622 Answers
SOURCE: my 3mth old e522brxu fisher
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
Posted on May 26, 2011
I have a 10 years E521T fisher & paykel. The freezer compartment is working fine, however the fridge compartment is not working even adjust temperture. It's beeping and can be reset with pressing
From thee sounds of your issue you will need a sensor or a fan motor to move air from one section to another. Most likely this would be a fan motor located within the freezer section either not running or air flow is obstructed and can't leave the freezer section to enter through passages to cool the other section. Locate the air ports within the refer section, open freezer door (is there air coming out of air port in this section?). Now, close door to freezer, (is the same air flow still there?). If not you have an air flow restriction and this would need to be addressed. Good Luck, hit me up if you have more questions
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 04, 2014 | Fisher and Paykel Active Smart® E522BR...
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
I have a 4 year old model WGP 95 pump which has been running trouble free until a few weeks ago since when it has developed a recurring earth leakage problem which seems to make no sense. When operating...
I assume the RCD is an overload protection device. I would check the pressure side of your system and be sure it is clean. It sounds like it is building up back pressure. and overloading the pump motor.
Aug 14, 2013 | Little Giant Plumbing
Beeping constantly in middle of night
My fridge (E440T but I believe the E522B is similar) also had a broken fan wire. I pulled off the panel and re-soldered the wire. I also created a document for others to follow if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Oct 03, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
