Question about Activision Cabela's Big Game Hunter for Nintendo Wii
Hello can you tell me what i must do when i want raise out of the canyion after falling in. thank you for your answer.
WHAT IS USED FOR THE EQUAL TIME
The calculator is doing exactly what you tell it to,
You first input 1.06. Then you press the y*x key, which tells the calculator to raise the previous number on the stack to the 1.06 power. Then you input 10. The result of all this is 10, as your calculator shows.
If you want to raise 1.06 to the tenth power, press 1 . 0 6 ENTER 10 y^x.
My 12c shows 1.7908 for the above.
Sep 08, 2016 | HP 12c Calculator
How do I change a broken needle?
You need to tell us make and model when you post a question for us to give you a really good answer.
Here the generic way to replace a needle:
  1. Raise the needle fully.
  2. Look for a thumb-screw right where the needle joins the needle mechanism.
  3. Loosen the thumb-screw and catch the broken needle when it falls out.
  4. Put a new needle in the place occupied by the broken needle. Be sure the flat side of the needle is away from you.
  5. Tighten the thumb-screw.
Jun 10, 2015 | Sewing Machines
I'm having problems with the exhaust vent on my Neptune filling up with water
Hello, Thank You for using FixYa. I will be helping you today. If your vent is filling with water it is either too long or blocked with lint somewhere. Sometimes if the vent cover outside the house falls off rain water may get into the vent also. There is nothing in the dryer that can cause this it is a venting issue.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We have a lte6234dqz and when we moved it by laying it down we found a clevis pin. Can you tell me where it came from?
Hello, Thank You for using FixYa. I will be helping you today. It is the shipping pin from when the unit was new. They fall into a plastic cup there should be three. They are not needed and the unit is ok.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Whirlpool LTE6234D Top Load Stacked...
Mdbh989aww3 I have heavy black rubber sheet material breaking off from the bottom of my dw and falling on the floor underneath the dw
Hello, Thank You for using FixYa. I will be helping you today. It is for sound. It is very common for it to fall off. It will not hurt anything if its coming off. I know it shouldnt but it does..
Jun 21, 2011 | Maytag Dishwashers
Dishwasher falling forward
Open the door and look up at the leading edge of the dishwasher..you should see two metal eyelets that may or may not need to be bent up or swung into position. Take two sheetrock screws and screw one into each eyelet up into the underneath of your countertop that will hold it in place
Oct 05, 2009 | Dishwashers
I dont know where is fuel filter in vw passat 1.6
Hello jansivicek: My name is Roger and I will help you. To locate the fuel filter raise the right rear of the car. Remove or at least pull back the fender liner. The fuel filter is located behind the right rear housing liner. Please rate the quality of your answer. This way we know you answer was helpful. Thank You for using Fix Ya. Roger
Sep 19, 2009 | 2000 Volkswagen Passat 4Motion
REAR AIR SHOCKS
First, you may have leaks in your bags, causing your suspension to drop. The other possibility is that your rear suspension level sensor is faulty, causing the suspension to readjust itself incorrectly.
Jul 24, 2009 | 2000 Lincoln Navigator
How to change the fuel filter on my volvo s40 2004
Hello francecslouis: My name is Roger and I will answer your question. The fuel filter is located under the vehicle. Just in front of the right rear wheel. Raise the vehicle for clearance. Support the car in case the car should slip and fall. Look just in front of the axle and you will see a in-line filter. If you are not sure what it looks like purchase the new one and compare to the old one. Please rate the answer you received. this way we know you received the correct information. Thank You for using Fix Ya. Roger
Jun 20, 2009 | 2004 Volvo S60
Location of crankshaft sensor
Hello mitchoreb: My name is Roger and I will be glad to help with your answer. You will need to raise the vevicle in order to see the sensor. Make sure to use safety stands when ubder the vehicle when raised up.Look in the area behind the oil filter.Just in front of the knock sensor.This will be just above the oil pan rail.The knock sensor is a round sensor with a round plug.The crank sensor should hove a oblong plug. You should have a picture along with this reply. Should you need any further help please just ask. Please rate the answer you received as this way we know you recived helpful information. Thank You for using FixYa.Roger8d42463.jpg
May 09, 2009 | 1998 Pontiac Sunfire
Activision Cabela's Big Game Hunter for Nintendo Wii Logo
182 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
Rick Moore
Rick Moore
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
