Question about HP Photosmart 2710 All-In-One InkJet Printer
My HP Photosmart 2710 keeps shutting down, either when printing, scanning, or sometimes just on its own. I can only get it to restart by removing the power plug from the power supply and reinserting it
  • HP Master
  • 1,591 Answers
The most common reason for this is that the power input in the printer has a bad solder joint.
Wiggle the power connector at the back while the unit is powered up.
If it goes off, then that connector inside the printer just needs to be soldered back down.
The other possibility is that the power adapter itself is failing, which is really hard to test without another power adapter to test it with.
Posted on Mar 19, 2011
Are there any software for windows 7 for
No, there are no drivers for this printer with W7.
However, we can add the additional drivers and make it print.
Please click on Start on the computer----Devices and printers----Add a printer----Add a local printer
----Select Use an exhisting port-----Please select LPT 1 and from the drop down selet USB 001
(Please do not proceed further until we get USB 001)
----Next----On left Select HP----
On right select HP Photosmart 2710 or any related Photosmart printer series----
Next----Next----Select do not share this printer----Next----Print a test page----Finish
Jul 01, 2010 | HP Photosmart 2710 All-In-One InkJet...
HP 2710 Photosmart scans but refuses to print. I'm using OS 10.6
Johay, It seems to be a driver problem. Please follow the link below to un and re install the drivers of your device.
Installing Devices on PCs and Laptops
Jun 13, 2010 | HP Photosmart 2710 All-In-One InkJet...
Running windows 7 with HP 2710 will print but cannot scan
Make sure that..wires are connected properly between printer and computer. Wire cud be faulty. Check if scanner lite is moving on scanner bed. There cud b faulty scanner.
Nov 29, 2009 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 stopped scanning
hi
first try to do the flee power cycle of the printer that means that to go ahead and unplugg all the cable and replugg it back after 30 sec and try to restart the computer ,,,check that wether it works or not
if not then
go to run and in run type in devmgmt.msc it will open the device manager of the computer.
then in device manager check for the USB PORT ...now under the usb port number check that it is being hooked on the right pannel ,,,,check for the setting and change to the desire option and the printer will definetly work
Jul 22, 2009 | HP Photosmart C7180 All-In-One InkJet...
I can print wirelessly but when I try to scan, it says that I need to downloan HP software. But didn't I do that already?
you may have to remove the latest HP All-in-One software then re-install it again.. you can download it from this link, http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=420428&
if you have Mac OS X - this might be helpful,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=420428&rule=12094&lang=en
May 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
HP photosmart 2710. When a document is sent to print, I get a 'save as' screen. can't make it print.
try uninstalling the software shut down the pc, restart, then re-install printer software
Oct 30, 2008 | HP Office Equipment & Supplies
Printer will not print wireless
my 2710 HP printer prints every thing fine from all the other programs but it does not print sheet from excel program any one can help?
really appriciate it
thanks,
Ray
Mar 18, 2008 | HP Photosmart 2710 All-In-One InkJet...
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
