I have had my Plenio 3000 for about a year. When I powered it up it said out of memory. Now I cannot get to navigate anymore. I have tried to reload the card but I cannot load it.I tried a 2 GB card but it wouldn't recognize it. So I am bacg to my 1 GB card. Any thoughts? By the way Why is your web site trying to download information from my pc? It's trying to get my bank account info but I have that blocked.
Plenio Is Litttle Picky On What SD-Chip To Use, I Just Upgraded Mine To 2GB SD-Memory
Chip Purchased From Walmart, Mgr Name Is a PNY, Black and Gold Display Case, also
Say's OPTIMA SD Ultra High Speed, Mgr Bar Code# P-SD2GB-FS [On Back Of Display Case]
During My Upgrading to 2GB Chip, Using Plenio-OEM CD," Navigation Map Data Base" DVD-ROM
Version 4.0. Had same problem,
Using Plenio Folder on PC " C:/Plenio/V-Up Pro 3000/VUPro3000.exe, checked box, SYSTEM UPGRADE, Selected SD Memory Drive, [My PC Was F:/], then software should detect SD-Chip
and Display Free memory Size, If So, Then Select Next, Should Take Aprox 20 minutes to Complete
Installing Plenio Software From Your PC to SD Memory Chip.
I'am Sure That IS How It Went For You, Mine Did Not Work For Navigation Either, Everything Else Was OK.
Take Your 1GB Chip And Copy To Your Hard Drive, ie; C:/Plenio/OEM_Plenio_1GB_SD
[Good To Always Have A OEM Backup]
From Windows Explorer Locate This Folder Name On The 1GB SD Chip Directory: MobileNavigator.
In This Folder, Locate File: Device.cfg & MobileNavigator.exe & rdat [No File Extension Displayed]
1] Copy These File's To Same Folder On Your 2GB SD Chip.
Your System Now Has Knowen Operating System Installed and should work like before,
might want to recheck your personal setting's.
I also noted using Plenio Software, I could not Check-Box "OS Upgrade" I think this is why
It Did Not Work. Still have to ask Plenio-Tech About This.
www.dvssale.com
Contact Dan Kim [USA] 408-970-3388 office
Email [email protected]
I also Noted CD I have Installed Larger Map File Size Than The Preloaded 1GB-Chip Has On it.
located in the "Cities" Folder, file: iusa_110mb_en_standard_cg.cdt 114,232KB
CD Ver 4.01 Installed this File; iusa_180mb_en_cg.cdt 184,145KB
Also Came Up Somewhere With Plenio a: iusa_50mb_en_cg.cdt 48,258KB
I'am Not a Plenio Tech-Rep Just A VXA-3000 Owner
Also Installed 103 MP3's and 20 .bmp Pics/Slideshow, had 480KB Free Memory Left
[email protected]
