Question about Zebra 300DPI W/FULL ROLL REWIND [zm400-3001-5000t] Printer
Our zebra zm400 is set to ****-off and everything seems fone for a while, then the backing take up roll (rewind) stops rewinding and the backing starts to hang down the front.
  • 96 Answers
Go into the setup menu and check to see if it is currently in **** mode. Or print config to verify mode. If it changes from (****) to tear or rewind, etc. , then the driver is set wrong. Change the driver to **** mode.
Posted on May 04, 2011
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
My kimball electromatic player piano won't automatically rewind, or even stop, when it reaches the end of the roll. It just keeps going and pulls the tape off the roller. If I press the stop button, it...
Look near the end of the roll for a hole or other trigger method that triggers the stop. It could be a hole in just one column or possibly a heavy mark on the roll. The later would be sensed by an optical pickup which MIGHT have a lamp burned out. From the site:
http://www.player-care.com/system55.html
It appears that vacumn via holes triggers the stop and the rewind by "pouch" switches. I suspect those swithches trigger and lock the relays in the same pix at the site.
First thing to do is to see if those switches actuate at the end of the roll so as to stop and then rewind.
Aug 28, 2010 | Music
How to use my ZEBRA 400 AS A REWINDER
Hit the Setup/Exit button to enter into the Menu area Hit the "+" button until you get to the output option (Rewind, peel, tear off, etc)
May 03, 2010 | Zebra Z4Mplus Printer: Peel with Full Roll...
My Zebra Z4M stopped rewinding the used liner
This could be something simple like not having rewind (peel) selected in the setup menu. Or you could have a bad rewind motor or main logic board. Remove the cover and make sure no plugs have come loose. There isn't an easy way to check the motor or logic board unless you have a spare that you can swap.
Jun 25, 2009 | Zebra Z4M Printer
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Zebra 4m
If you are in rewind mode and don't rewind the printer will pause while the rewind spool tries to catch up.
Jan 10, 2008 | Zebra Z4Mplus Label Printer
Flashing HI
there is a flexible ribbon cable carrying signals from camera body to the lense assembly. Due to regular use it gets worn out, thus it gets broken and is not able to perform the task for which the camera has given the signal. in your camera also the same flex cable is broken. Get it changed at some good repairer
Oct 26, 2006 | Pentax IQZoom 928 35mm Point and Shoot...
Zebra 300DPI W/FULL ROLL REWIND [zm400-3001-5000t] Printer Logo
473 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
