Question about Microwave Ovens
Creda excell washing machine wont drain water how can i check the hose for blockage
    Genius:
  • Microwave Ovens Master
  • 1,474 Answers
Get a basin and drop te hose down to floor level if it flows easy then its free of blockage...
Posted on Mar 19, 2011
  • chhatarpal singh Mar 19, 2011
    in the back washing machine, housing pipe distributor open
Why wont My Daewoo DWF-750 washing machine not empty water automatically
You've probably got some debris in the pump, or blocking the pump inlet. If you can do this without making a mess (or shocking yourself,) try backflushing the drain hose.
May 06, 2014 | Microwave Ovens
Water drips from the back upper area inside the refrigerator. Sometimes I find a small puddle of water on the floor. It is only 6years old. Model CTB1821ARW
Look at the back wall of your fridge and at the top centre you will see a small plastic tray about one and a quarter inch square, this is part of the drain system for the freezer defrost cycle, you will find that the drain tube from this tray is blocked with debris from the freezer.
To clear the blockage:
At the outside rear of the fridge you will see a rubber tube that runs down the centre and disappears under the lower section where the compressor is located, pull off the grill below the fridge section door at the front of the unit, locate and remove the water evaporation tray, locate the the end of the aformentioned rubber tube, insert the end of a water filled baster into the end of the tube and hold it securely in place with one hand and then squeeze the baster bulb with the other hand to force water up the tube, you may have to do this more than once but it should clear the blockage, if not you may have to use a short blast from a air hose.
When you replace the evaporation tray ensure that the end of the rubber drain hose is located in the tray.
Aug 12, 2011 | Maytag Microwave Ovens
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Ice machine making ice, but storage bin full of water
Check the drain hose where extra water would drain. Possibly plugged or blocked..
Feb 24, 2011 | Microwave Ovens
My dishwasher is not draining. How do I fix this please.
first open the access cover by the floor after turning off power,then remove the hose clamp on the discharge side of the pump and with a shallow pan catch any water that flows out of pump,then check the hose from the discharge side of the pump to the garbage disposal or where ever it drain to,if any of these are clogged the pump either wont drain or will not run to drain,then remove the 2 wires off the pump and check the motor windings for continuity,every unit is different so you need to get this motors resistance specs and check its resistance if its open replace it
Nov 17, 2010 | Microwave Ovens
I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
Hello there:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jul 08, 2010 | Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Dishwasher does not drain. Drain valve is very hard to work and has burned out the solenoid. Can you tell me exactly how to get these parts out of the dishwasher. Do I have to replace the pump to replace...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 09, 2010 | Microwave Ovens
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
