Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer - timer signal
Does the timer need replaced because the ringer does not go off - that is - is it a ringer problem or a timer problem?
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Does the dryer keep running and not turn off? Then it is the timer!
If the ringer does not work then it's the ringer!
For this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
How to remove and replace the control panel?
Thank you for your inquiry, Joe!
I see you would like to remove and replace the control panel on your Frigidaire dryer, GLEQ2152ES. Unfortunately there are no instruction guides on how to remove the panel. I have included a parts schematic for your dryer and I hope that information is helpful for you. -Matt
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=GLEQ2152ES+&User=&Search=Search
Aug 30, 2015 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer will not stay on for
Reach inside and turn the drum by hand. It should be very eay to turn. If it is not easy to turn then something needs to be replaced such as glides or drum bearing.
Sep 06, 2013 | Frigidaire GLEQ2152ES Electric Dryer
FRIGIDAIRE DRYER MODEL GLEQ2152ES NO HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Noisy Frigidaire Electric Dryer
Here is a tip that I wrote that will give you somethings to check out...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric will not turn on
Check the terminal block where the cord attaches to the dryer. Sometimes a bad connecion can cause the terminal block and/ or cord to burn up.
Jul 21, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire infinity
replace the timer unit as you cant repair them
Jul 01, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
