Question about Alpine MRP-M500 Car Audio Amplifier
I need to know how to wire 2 Kicker comp 10" subs
    Sergeant:
    Novelist:
  • 185 Answers
You can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Posted on Mar 19, 2011
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Daisy Chaining 2 Mono Amps to 1 Sub?????
i beleive they have to be the same amps.an i think they have to be able to handle being strapped together.id look into getting new amps to run it elemental deisgns i know u can strap them together an controll them from the master amp.i dont think alpines handle 3ohms that good either.im going to check a few things an see if u can strap them two amps toghter.if u need more help email me bertman285@hotmail.com
Oct 15, 2009 | Alpine MRP-M500 Car Audio Amplifier
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Oct 18, 2007 | Alpine MRV-T757 Car Audio Amplifier
Alpine MRP-M500 Car Audio Amplifier Logo
720 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
