Question about Neff Microwave Ovens
How do I take a built in MW 5631 out - Neff Microwave Ovens
I have a GE Profile microwave oven. It has power and I can input the time but it clicks and won't heat
Our MW did the same thing. Called the dealer and was told they are so cheap to buy, he doesn't repair them.
well ours has the vent hood and it's built in. Wasn't cheap at $350.
turned out to be a micro door safety switch that I got 2 new ones from eBay for $6 and free shipping.
if you are like me, when I would check the food while cooking by opening the door while running is what burned the switch out. So now I turn off the MW by button and not just open the door. Sodbust
Dec 11, 2017 | GE Microwave Ovens
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Panasonic microwave...
Without HV test equipment it is quite difficult to determine if it is the magnetron or inverter.
5 years is a little short for magnetron failure but it appears that this is about all you can expect these days from a magnetron - the best I have seen was 11 years. I have not seen an inverter failure as yet (although I am not a full time repair man). The main reason I suspect it is the magnetron is the short time period from start to stop - it is typical of magnetron failure in Panasonic microwaves.
As regards door hinge side, that is one of the great unknowns. I suspect it comes from most people being right handed but even refrigerators could be specified as right/left hand hinged originally and now can be changed by customers.
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Panasonic MW- Arcing
You're on the right track. That panel is the waveguide cover.
This is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover in the waveguide just out of sight.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr
Nov 07, 2007 | Panasonic NN-T990SA Microwave Oven
GE Microwave JE1640 works only when holding the switch
VK, most likely the switch body has become loose and it's out of adjustment. Unfortunately, to gain access to it, you'll have to remove the MW from the cabinet, set it on a suitable work area and disassemble it. Before doing anything like this, please read the following link carefully and ask yourself if you're up to it... http://www.gallawa.com/microtech/safety.html Remove the trim then remove the screws holding the MW. Pull the MW out and rotate slightly to see where it's plugged in and unplug it. Then pull it all the way out. Remove all the aluminum trim from the MW and all the screws holding the cabinet. To remove the cabinet, stand behind the MW and grasp both sides... pull back and up at the same time. Set aside. NOW!!! DISCHARGE THE CAPACITOR AS PER THE INSTRUCTIONS IN THE LINK ABOVE!!! OK, up by the control panel, you'll see the latch/lock assy. (it has 3 brown switches mounted to it). It's held in place by 2 screws, the lower screw is the one you'll be working on. Adjust this by opening and closing the door and watch the action on how it works and make your adjustments as needed. Now, you'll need to test it before reinstalling. Plug it in, BUT DON'T TOUCH ANY WIRING! Now give it a try. If you need to make another adjustment, DISCHARGE THE CAPACITOR AGAIN BEFORE DOING SO!!! Do this every time you plug and unplug! Continue adjusting 'til you get it. Now, there's a chance that one of those switches is about to go bad and the mounting bracket is fine. In this case, those switches are generic... not GE specific. Remove the wiring from the switches and make notes on their respective locations. Remove the switches from the bracket (starting from the top) and label them 1, 2 and 3. Take these to your local appliance parts store and ask for generic replacements, they are cheap... about 5 bucks each. Then replace them in the same order you removed them. And re-test. This will get you fixed, but please be careful working on Microwave ovens. They are dangerous!
Sep 27, 2007 | GE JE1640 Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
