Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
Bradford white ttw1 blower making a whinning noise, can I lubricate or do anything about it.
4 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Posted on Jun 01, 2009
SOURCE: I need an upper element for my Bradford White
Go to your local hardware store, i perfer lowes or ferguson's
Posted on Oct 08, 2009
  • 102 Answers
SOURCE: Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
Posted on May 05, 2010
Noisy barring motor
bradford white blower . Sir this link will provide you with a variety of sources to buy the blower. The average is far below your quoted target. Since this is a nut and bolt with a direct plug or 3 wire assembly, bradford white blower 239 40614 00 . Here lies a different price point.
If this blower is out of warranty and its been running a long time. The value of the direct replacement is a far better choice to average, although more, odds; are to revisit it sooner than later without a direct replacement.
If you need help to do this job? It can be a do-it -yourself. Make sure the unit is locked out and give it a whirl. If not? The replacement is approximately 2/3 that of your suggested quote. The ball is always in your court.
Be safe. Carbon Dioxide does not discriminate, you never hear anyone from the cemetery complaining. If this is iffy. Get a technician. The extra 1/3 may justify the worth of a life investment. Fare. Well.
Apr 17, 2014 | Fasco Bradford White Water Hot Heater...
Exhaust blower
If it has no oil ports, replace the motor
Dec 02, 2013 | Fasco Bradford White Hot Water Heater...
I have a Bradford White water heater (model# MITW50L6LN10) that started making noise yesterday. Tonight when the family got home we started a bath for the kids and surprise surprise no hot water left in...
Probably cheaper to fix existing water heater.
The problem might be the power vent, or the power vent might be short cycling because the gas control valve is bad, or vacuum switch has gone bad.
Call Bradford White and get their recommendation for your specific model.
http://www.bradfordwhite.com/contact.asp
http://www.bradfordwhite.com/supportserv.asp
http://www.bradfordwhite.com/findaserial.asp
Bradford White is very good brand of water heater
Rheem, Richmond, GE are good.
I prefer the AO Smith, American, State, Reliance, Craftmaster. Kenmore, Whirlpool brand since air intake screen is located on bottom of unit and can be inspected and cleaned without removing burner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 09, 2013 | Water Heaters
Lochinvar DVN051 Water heater, I checked voltage on transformer, fine, checked pressure seitch, fine, blower runs fine, gas is on and stat clicks when I rotate it and kicks the blower os, I checked th
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also: Scroll up on same page for Pressure Switch heading.
Lochivar is made by Bradford White I believe.
Same troubleshoot page has link to Bradford White service manuals, and service manuals posted by AO Smith, in case this product is through one of their subsidiaries.
Rheem does not make this product, good thing for you because Rheem doesn't post service manuals.
Sep 09, 2012 | Honeywell Water Heaters
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Noisy water heater blower
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Feb 10, 2009 | Fasco Bradford White Hot Water Heater...
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
210 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
vince
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
