Question about Baumatic 23 in. BDW14 Built-in Dishwasher
I have a bd15 and the lower cleaning arm is no longer working,ie water does not come out of it. I have taken the arm off and it is not blocked. Any ideas please
  • Baumatic Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
The top rack of dishes are not getting clean. I
you need to check the upper wash arm for blockage from debris,if this is not the case,then you need to replace the water conduit from the lower sump area to the top arm,after time the water erodes the plastic conduit especially where it connects at the arms and water gets by these areas and can no longer build pressure to spin the wash arm
Apr 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
Lower dishwasher arm not rotating
Probably blocked spray arms is the cause of the unit not cleaning properly or rotating. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | GE Dishwashers
I have a Bosch Dsihwasher - model SGS53A. The lower washer rota arm is not turning. I have checked that water outlets are not blocked in the arm - all clear. The up arm turn normally. Steve
arms rotate by water volune and pressure / ck to see if the screen in bottom and the cup sreeen is clean . if not clean it with a stiff nylon brush reinstall and try it again // also ck water level if too low this would cause problem .. float or pressure sw causes low water . or water valve filter screens .. hope this helps let me know .. **** .
Dec 04, 2009 | Washing Machines
The bottom rack is not cleaning properly. Its as if the water pressure is not enough to wash the plates clean.
Ensure that forks or other cuttlery is not poking out the bottom of the basket and obstructing the lower wash arm.
Check to see that the lower arm is receiving water(and not blocked) to do this empty the machine and put a plastic bag around the arm that engages with a socket on the back of the washer this will block water to the upper arm and increase the pressure to the lower arm. Set the machine to rinse when you can hear the machine start to work open the door quickly and see if the lower arm is spinning!
Nov 07, 2009 | LG Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
The dishes no longer get clean even though the water is getting through....are there filters I need to clean or could the soap dispenser be a problem....please help
there are filers in the inside bottom of the machinbe which should be taken out and cleaned regularly.
problem may be that the spray arms are not rotating. open the door when in cycle and check each arm rotates(you will get a bit of water out)
if they are not, the problem is probably debris in the arm so take them out and clean (this is quite tiresome to do and the usual culprits are rice and sweetcorn)
the arms only rotate by water sqirting out of angled jets at the end of the arm and if these are blocked then arm doesn't turn
Jul 12, 2008 | Dishwashers
Lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
May 20, 2007 | Maytag 24 in. MDBS661A Built-in Dishwasher
Baumatic 23 in. BDW14 Built-in Dishwasher Logo
117 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
