I cant print in my cannon 1980 the printer say's offline but the power of green light is on what will i do pls help
  • Office Equip... Expert
  • 222 Answers
try to reinstall printer driver or change printer port from printer properties menu.
Posted on Mar 19, 2011
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
Service mode
Which printer model you are using??
Example: For cannon printer follow the given steps....
  • Plug in power cable
  • With the printer power turned off,while pressing RESUME/CANCEL button,press and hold the POWER ON button. (Do not release the buttons)
  • When the Power LED lights in green,while holding the POWER ON button,release RESUME/CANCEL button. (Do not release the POWER ON button)
  • Press RESUME/CANCEL buttons 5 times. (Each time the RESUME/CANCEL button is pressed,the ALARM and POWER LED lights alternately. Alarm in orange and power in green).
  • When the POWER LED lights in green the printer is in service mode and ready for service operations.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Canon PIXMA iP1800 InkJet Printer
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 01, 2009 | Cannon Canon i960 Photo Printer
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Printing problems
offline means it cannot detect the presence of the printer, though virtually present, check the ff
1- cable are intact, USB or Parallel to PC
2- power line, light on the printer itself
if ok, then reset all queued jobs and restart the PC once again
dont forget to mark my suggestion pls
Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
23 people viewed this question
k24674
jasbo
jasbo
