Question about Microwave Ovens
We have a new Eco Max Bagless vacuum cleaner. Unfortunately we mistakenly disposed of it by mistake. Can you supply us with a fresh copy? We have the MC-UL592 model and the only number I can see is 201008190969. My address is 1058 Waters Edge, Lower Burlington Road, Portishead, Bristol. BS20 7AS, and my 'phone number is 01275 397226. I should be most grateful if you could send me a copy.Many thanks, Anne Patrick
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 19, 2011
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
I cleaned the exterior and interior of my sunbeam microwave SM0701A7E and now some of the buttons don't work. What are the cleaning instructions and warnings of this model? How can i get the buttons to...
A common mistake people make when cleaning appliances is to spray cleaner on the keypad, then wipe it off. Unfortunately, this is wrong, and can allow some of the cleaner to work its way around the edges and into the contact surfaces. Over time they may dry and start to work again, but there really isn't any way to repair the problem except by replacing the keypad if they don't work.
I've seen this oftent, especially on TV sets where people spray the face of the picture tube and the cleaner runs down onto the circuit board inside. All kinds of weird things can happen then. The correct way to clean is to spray a cloth or paper towel with the cleaner and then wipe the keypad. On the interior, you can spray the cleaner directly on the cooking cavity surfaces. Just watch for the hole in the bottom where the turntable shaft comes through if your oven is so equipped. You want to avoid flooding the turntable motor, so use the spray sparingly, or spray the cloth first and wipe.
I haven't yet been able to find a source for the keypad. For small ovens, it's often hard to find model-specific parts like the keypad. And when you can find them, it's sometimes not much less expensive than a new oven. (A local store in my area advertised a 900-watt countertop oven for $59 in Sunday's newspaper.) If I do locate a part number, price and source, I'll post a follow-up comment with the information. But you'll probably be better off replacing the oven if the keys don't heal themselves.
Jan 18, 2011 | Microwave Ovens
I have just had worktops and new sink and franke turbo waste disposal WD500 fitted by Granite Transformations but need a handbook for the waste disposal - they dont have them and I have no idea on...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
I hope this helps.
Jan 04, 2011 | Microwave Ovens
Everything is working, but no heat. lights come on, turntable turns, fans run, but no heat
Normally this would indicate that the diode in the power supply for the Magnetron (microwave radiation emitter) has failed. I would recommend that the unit be serviced by a professional in this area, or disposed of because of the following:
1 The power supply for Magnetron Tube the produces thousands of volts and can produce a lethal shock even though the machine is turned off and unplugged. Really, I'm not kidding.
2 Working on a Microwave Oven can expose you to high levels of Radiation which can immediately
Damage internal organs.
That said, there is another even better reason.
3 Microwave Ovens are now very inexpensive to replace.
Even though I personally know how to fix them, I can't be bothered.
I hope I have been of help
Happy New Year,
Best, Mark
Jan 01, 2011 | Samsung SMH9187 Microwave Oven
I have a Henry vacuum cleaner. The nossle that screws into the vacuum cleaner has become loose. Would you advise a website where I can get a new part?
Providing it is not broken, the "cup" end of the black flexi hose can be glued and screwed back on (reverse thread). Equally, if you have the removable type of threaded "nose" on the base, this too can be glued and fitted back in place. Most regular glues will do. For parts, check local directories for Janitorial or cleaning product suppliers, or alternatively contact the manufacturers Numatic who will post you the parts you require.
Dec 20, 2010 | Microwave Ovens
Dishwasher does not drain. Drain valve is very hard to work and has burned out the solenoid. Can you tell me exactly how to get these parts out of the dishwasher. Do I have to replace the pump to replace...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 09, 2010 | Microwave Ovens
My daughter mistakenly put a stainless cookware inside and the microwave spark, now its broken
possibly sand effected areas and touch up with appliance paint really well to perevent arching again.... this only occosionally works it most likely occurs again,, i hate to tell you this but most micros are disposable items these days after parts and maybe service call u could buy a new one... i would tell you to just buy a new one but u could try to see if that tip works hopefully it didnt damage any parts internally like a fuse or magnetron.. hope this helps
Feb 03, 2010 | Whirlpool Microwave Ovens
Oven operating while empty
Yes, as long as you don't smell any burning, but as always, no microwave should ever run unattended.
Jun 03, 2009 | Microwave Ovens
Blowing Fuses
never put higher fuse then what is already there can cause a fire microwave are being made more disposable now either use warranty or buy a new one i am lucky if i get one to last a year before it starts acting up cheaper to buy new one then to have it repaired
Dec 03, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
