Question about Miele G880 Dishwasher
Water will not drain out of bottom of machine.
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Mar 19, 2011
The digital screen come up with F21. How do I fix this
F21 means the washing machine has a “water draining issue”, meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub. If you have a front load washer then you need to locate the drain pump which is usually located on the bottom front of the machine. If you have a top load washer then you need to make sure the drain hose is not clogged or pinched. The drain hose is located in the back bottom of the washer
Mar 06, 2018 | Washing Machines
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
Water won't drain
Maybe the filter is blocked. It should be located near the bottom of the machine at the front and should unscrew. Have a dish and bowl handy to collect the water.
Oct 08, 2012 | Cars & Trucks
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
WD1000 has too much water
You are not hooked up to the drain properly. If you do not create a trap the water will drain back into the machine. The drain tube goes from the bottom of the machine up to the top and then back to the bottom. You need to run the drain tube up to a final drain or other trap. You can even create another mini trap by making a loop before running into the drain. Whatever you do just try to get the hose to go about as high as the highest point at the back of the machine, but not higher, as it will create a siphon and flood the machine.
Jan 24, 2010 | Malber WD1000 Front Load Washer/Dryer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Leaks water out of the bottom of the machine.
check the pipe the drain hose goes into. if this is blocked the water will overflow out of it. or there could be a split in your drain hose
Jan 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
How to drain water after laundry?
at the bottom of the washer is instructions on how to drain the water inside the washer. A small hose is contained at the bottom right hand corner with a white plug (you need to pull on it hard). Once you remove the plug from the small drain hose it will drain all the washer water.
Before you do all this make sure you disconnect the electrical wire or turn off the breaker switch to the washer machine.
Dec 22, 2008 | Samsung WF337AA Front Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
Miele G880 Dishwasher Logo
254 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
