Question about Linksys Wireless-G WRT54GR Router
I have my pc with vista connected without any problem, i have just got a new pc with windows7 which connects to the wireless network, but i can't get on the internet, as the ipv6 connectivity is showing no internet access. Any ideas?
    Sergeant:
    Champion:
  • 236 Answers
Windows & has a pretty good user friendly help section which deals with getting connected. I would reference that under the help and support section.
Posted on Mar 19, 2011
CAN THE DELL AIO 948 PRINTER BE USED FOR SHARING
Yes, If it is connected to a computer on your home network, right click the printer, setup sharing. For example, if you have a laptop on the same home network, Add a network printer to the laptop and print wirelessly without a wireless printer. This may help clarify: http://windows.microsoft.com/en-US/windows7/Install-a-printer-on-a-home-network OR http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Dec 31, 2012 | Dell 948 All-In-One InkJet Printer
The wifi is not working
There are soooo many things this could be. I will give you every idea I can. Respond to this post whether these steps work or not. If you do, I will continue working with you on this until you can connect.
1.) Can any other computers connect? If you have other devices which can NOT get online, the issue is with your modem/router. Unplug the power cable(s) to your modem and router (if you don't have a router, disregard anything I explain regarding a router) AND SHUT DOWN your PC. Wait about 1 minute and plug the power cable into JUST YOUR MODEM. Wait 3 minutes for it to get a connection. Look at the lights on your modem to ensure they look normal (the "ethernet" will be OFF. That's OK.). After 3 minutes has passed, plug the power cable into your router (IF AND ONLY IF you do NOT have a router, turn ON your PC). Wait another 3 minutes and turn ON your computer (If you have no router, you just did this and it may be disregarded.) ---- In case the whole PC/router makes little sense: If you have no router and just a modem and a PC, then 3 minutes after you plug the power cable back into your modem, turn ON your PC. If you have a router, then follow the instructions exactly). ----
2.) Check for a switch on the left edge or front edge of your laptop which says "Wireless" or "Wifi." Be sure it is in the ON position (Not every laptop has this. Some have a wireless button above the keyboard and others have nothing at all.). It is very common for a user to accidentally bump this switch to the OFF position without realizing it.
3.) Perform a System Restore to take your PC's settings back to when it was working. Click Start/Programs (or All Programs)/Accessories/System Tools/System Restore. Go through the System Restore wizard to select a date BEFORE this issue happened. System Restore should NOT be interrupted. It can take up to 20 minutes in some cases. When it begins, set a timer for 20 minutes, walk away, and come back after that time has elapsed.
3a.) Windows XP: http://support.microsoft.com/kb/306084 3b.) Windows Vista/Win7: http://windows.microsoft.com/en-US/windows7/products/features/system-restore
4.) Clear your network settings from your PC and then reconnect to your network (if you do not know yourSSID (network name) and wireless network key (wireless password), then do not do this step. Instead, respond to this answer with the brand of router you have as well as the operating system you're using). This is where it would be nice to know which operating system you're using. I'll do my best with this while not knowing your OS.
4a.) Windows XP: Click Start/Control Panel/Network Connections. Then RIGHT-click your connection labeled "Wireless Network Connection [#}" and do a normal left-click on Properties. The network properties window will open. Click on the upper tab labeled "Wireless Networks." Under the Preferred Networks section, click the network you're trying to connect to and it will highlight. Then click Remove (immediately below the list of networks). If you are not sure which network in this list you are trying to connect to, repeat this process until that white box is empty. Then click OK. Again, RIGHT-click your connection labeled "Wireless Network Connection [#}" and do a normal left-click on Properties. Click on the upper tab labeled "Wireless Networks." Then click the button "View Wireless Networks." You'll be brought to a window where you can choose a wifi network with which to connect. Click the network you want to connect to and it will highlight in blue. Click "Connect" in the lower-right corner of this window. It will most likely (not always) ask you to enter your Network Key (network password). Enter this exactly; capitalization (Big letters and little letters) matters!
4b.) Windows Vista/Win7: Click Start/Control Panel/Network and Sharing Center. Click on Manage Wireless Connections. In the list, click the network you're trying to connect to and it will highlight. Above the list, click Remove. If you're not sure which one is the network you're trying to connect to, then repeat until all of the networks are removed and the space is empty. Once done, goto this link (CAUTION!!! I would right-click on this link and choose "Open link in new tab" OR "Open Link in New Window" to allow these instructions you're currently viewing to remain open): http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
If none of this works, respond to this answer and I'll help further. I hope this helps!
Sep 25, 2011 | Toshiba Computers & Internet
How do I find the PIN number for my linksys WRT54G2S router
Are you try to connect to the wireless network on windows7 or windows vista computer?
You don't need to enter the PIN number. you can add the wireless network manually.
Follow this link to connect to the wireless network.
Apr 12, 2011 | Linksys Wireless-G WRT54G Router
I DONT KNOW HOW TO CONNECT TO THE INTERNET I NEED HELP WITH IT(INSTRUCTIONS) ON HOW?
This are the general steps for all types of routers.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 01, 2011 | Computers & Internet
I don't have wifi in my laptop acer travelmate 4335. what i have to purchase and how i have to connect the same.
Mongkey
Jan 31, 2011 | Computers & Internet
Cannot connect to wifi
The following can be applied to any routers. These are the general troubleshooting steps.
If problem persists, contact your router's manufacturer.
I hope this works for you. Good Luck!
Thanks.
Mongkey
Jan 30, 2011 | Computers & Internet
How to connect Linksys WRT150N to laptop on DSL
Thanks.
Mongkey
Jan 18, 2011 | Linksys Wireless-N WRT150N Router
How do i turn on my wifi
look for a button/switch along the side of your computer. This should allow you to turn on/off the wireless radio.
The rest is done through your wireless software in windows.
For Windows XP: http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
For Windows 7: http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
For Windows Vista: http://support.microsoft.com/kb/928429
Dec 26, 2010 | Coby PC Netbook 1ea
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Linksys Wireless-G WRT54GR Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
