Question about Nokia Cell Phones
My mobile 5233 is unable 2 read sim memory.due 2 ths reason its been in offline mode and anable to get back 2 general mode.even its unable 2 read sim contacts even when i have selected the sim memory option in my contacts settings.so plz suggest me solution.so that i can use my phone normaly in general mode.i can use all featurs preasent in it.but cannot use gprs/gps services in it so plz plz plz plz help me out
  • 101 Answers
1.YOUR MOBILE SOFTWARE MUST BE CORRUPTED.SO FIRST COMPLETELY DO "RESTORE FACTORY SETTINGS IN YOUR MOBILE".THE SOFTWARE WILL BE MADE NEW AND WILL BE SAME AS FIRST TIME YOU BUY. 2.GET THE GPRS SETTINGS FROM SERVICE PROVIDER AND THEN SWITCH OFF AND SWITCH ON THE MOBILE . THEN TRY USING GPRS SERVICE 3.THE WORKING OF GPS WILL DEPEND ON THE PROXIMITY OF THE SATELITE ,THAT IS THE LOCATION YOU ARE PRESENT.
Posted on Mar 19, 2011
My phone is offline. How do i switched on?
You can get it back online by changing the profile to anything else other than Offline. To do this, briefly press the power button. This bring up a menu. Select another profile, say General.
There are also other reasons why your phone stays in Offline mode even when you do that. The most common of these would be a problem with your sim card.
Aug 03, 2015 | Nokia E5 Cell Phone
Nokia 5233 fell in water and sim card registeration failed?
SIM card registration failed for a few reasons:
Poor contact out of the ground, such as mobile phones, SIM cards sometimes cause vibration and poor contact, or SIM lead to poor contact due to the long-term use, these cases turn off the phone, the card scored to wipe the surface of the card, best is rub the eraser with a good point, do not leave a crumb, do not scratch, see clean, you can plug in the card, boot look results.
2, the worst news is that your card burning, for many reasons, such as the most common: not shut down to remove the battery.
Test methods: the point of view of how your card on a friend's machine.
3 phone reader, especially parallel phone, new mobile phone.
Feb 16, 2013 | Nokia 5233 Mobile Phone
Nokia nuron wont read my sim card
When the phone is in offline mode, press the power button and you will get the options in list view. Choose the option General and the phone will become online.
Aug 29, 2012 | Nokia 5230 Cell Phone
How to remove the offline mode in nokia c7
Jan 04, 2012 | Cell Phones
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
Sir i hav nokia n70 mobile .i insert the sim in to mobile but phone is everytime offline mode
(1) Pl z go on profile mode and here activate a general profile OK (2) when u open a fone here a msg appear on your fone dat start" fone in offline mode" then u press a NO ok.
Aug 24, 2010 | Nokia N70 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Cell Phones Logo
48 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
