Question about Karcher Garden
When i connect my vario pressure lance to the gun it leaks like a sieve thus reduced pressure but when i fit my other accessories its ok???
  • 34 Answers
It sounds like you have the vario lance set to low pressure or "mix". If you twist the end of the lance you can increase and decrease the pressure. The setting you have it on is for when you are applying detergent through the pressure washer hence why it is a wider low pressure jet.
please remember to thumbs up, thanks.
Posted on Mar 25, 2011
Testimonial: "Thamx!! "
The washer is running but i do not get pressure
I had the same problem. Here are what I did to fixed it.
1. Ordered a O-ring kit from Amazon and put it on since there was a leak at the connection to the water gun (lance). It solved the leaking problem but the pressure was still low.
2. Then I took apart the water gun and back flush the water path. Once it is clean you should be able to see through by aiming it to a light. Any small particle of dirt blockage will cause side way mist and a lower pressure.
Hope it helps
Jul 18, 2015 | Garden
SPW-2 WONT RUN UNLESS GUN TRIGGER IS HELD ON ?
Check the intake and discharge water lines the filter screens get clogged with calcium etc. Make sure they are clean and clear.
Jan 22, 2015 | Garden
Karcher vario lance not working on high pressure
Sounds like the ball bearings in the vario nozzle are not in the proper position.
https://www.youtube.com/watch?v=3U6irpNnhfw vario repair
Oct 12, 2014 | Garden
How do i fit a new lance to Challenge MH02-1610GO pressure washer
Just the lance or trigger gun! Best of luck to ya!
Sep 23, 2014 | Garden
Kodiak manual
www.ppe-pressure-washer-parts.com/kodiak-pressure-washer-parts
NOTE: We are not KODIAK or affiliated with them. We did not sell these Pressure Washersbut do offer some parts that will fit them.
As close as I could fine. A hard one.
May 20, 2014 | Garden
Model CPW 1800 2 lance guns have developed leaks when pumping against dead end. Do these washesr have a pressure relief valve . Can this be replaced?
Byronj25, you can get the internal part that has most likely failed here. http://www.sparesgiant.com/p-4993-annovi-reverberi-210-gun-valve-kit-with-o-s-2291.aspx. You may want to dismantle it though and check that the black elbow tube has not failed also, as that part is obsolete and so would require a full new Lance. New Lance link http://www.sparesgiant.com/p-5002-champion-cpw-yellow-hl2-annovi-reverberi-gun-large-bayonet-40409.aspx
May 21, 2011 | Annovi Reverberi Garden
Washer doesn't reach enought output pressure. motor starts and stops at rendom.
First you have to do is try the machine without load. Attach everything as usual but do not attach the lance. Put on machine with water supply already on. If you close the gun the machine should stop. If you open the gun ( always with out lance)....the machine should start sending the water a bit far. If this is OK....then you have a lnance with a faulty, blocked NOZZEL.
NOrmally the machine stops when gun is released because there is a valve (Spill Valve) that actuates a electrical micro switch. This in turn closes off te elecreic supply...stopping the machine.
If with out lance your problem is still there....then the spill valve is faulty. AS I first said you must be sure that the nozzel is OK, so that you can blame the Spill Valve.
I raely service Spill Valves (Control Valves). I change with a new one. When open the cover using a TORX T15 screw driver....you locate the spill valve where there are 2 wires coming out. Some machines have the spill valve incorporated with the head and the intake and delivery valves unit. This I advize to change with new parts. These all in one heads are very good because at one go you change the spill valve and the other valves in one go.
Therefore in a few words you either have a blocked nozzel...or you have the spill valve faulty.
Also the delivery valves could be blocked...thus creating pressure inside and activating the spill valve to close off the electricity. You can also try to start the machine without gun and hose attached...but always with water being fed. NEVER put on a power washer without water being fed. And never store a power Washwer withpressure in it.
Fulltech.
Apr 25, 2011 | Karcher K2.26 Electric Power Washer
On high pressure it pulsates
NOrmally the machine stops when gun is released because there is a valve (Spill Valve) that actuates a electrical micro switch. This in turn closes off te electric supply...stopping the machine.
If with out lance your problem is still there....then the spill valve is faulty and the machine starts pulsating. AS I first said you must be sure that the nozzel is OK, so that you can blame the Spill Valve. When the spill valve is faulty the machine pulsates at high pressure.
So I advice again to try the machine with out the lance. If when gun is closed machine stops and stays that way ..it means the spill valve is doing its job. If when putting back the lance and the pressure starts to pulsates...the lance nozzel is faulty and thus causing simptyms on the spill valve. Also try to use machine with a new lance...having a new nozzel.
Fulltech.
Feb 18, 2011 | Karcher K2.26 Electric Power Washer
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
I have a karcher K3.98 pressure washer. The unit surges when I put the wand on and then it stops working. I tried cleaning the wand (didn't make any difference) I then tried another wand from my son's unit...
Dear davedulmage,
To see if the unit is OK....first you must switch it on without water and without high pressure hose and gun. If machinr works smoothly, try by attaching a water supply. Now run the pump with water coming out of the outlet. If also in this case all runs smooth, then attach high pressre hose with gun but without lance. Put on the machine with gun open(to reduce initial resistance) and when you see a clear flow of water coming out...close the gun. The machine should stop. In this case I am suspecting that when you open again the gun the machine will not work. So it seems that when pressure is built in the pump a fault is occuring in the Spill Valve or also called Control Valve. When the gun is closed and pressure built up, this spill valve contracts and switches the pump off. When the gun is opened, the spill valve extends, putting the machine on and closing a valve at the base of the spill valve. So in your case it seems that the spill valve needs to be renewed. A spill valve gets stuck by incorrect using of the pump. For example leaving the pump with pressure in it for a long time. Also it gets stuck by detergents and chemicals. Sometimes I lubricate Spill Valves with high quality silicon grease....but it is much more practical to change it. When a new spill valve is put in....always run the pump with no load. This by usiing the gun without lance or wands, resulting in low pressure. If all OK...add a lance or wand that you are sure it is good. One final thing....to get to this spill valve you must put apart the body and expose the pump. If you are not that good at doing this job...it is better done by a more knowledgeable person. But changing the spill valve is worth it....because it is cheaper than a new machine.
Regards,
Fulltech.
May 19, 2009 | Karcher Garden
Garden Logo
709 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
