Question about Microwave Ovens
The turntable doesnt turn. The clock, timer, start/stop and the heating do all work. How can I get this thing removed from the built in unit less than 4 years old
  • Microwave Ovens Master
  • 6,993 Answers
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.....
Posted on Mar 19, 2011
  • sunilkb Jun 29, 2011
    if the turntable turns freely then the problem is with the synchronous motor which turns the turntable. replace the synchronous motor. the voltage of the original motor may be different ie maybe 30 volts and 6 rpm. the common synchronous motor available in the market is the oscillation motor of table or wall fans but the voltage of this will be of 230 volts of 6 rpm itself but you can fit this motor and connect it to the same line of the cooling fan present behind the magnetron and the microwave works perfectly as before.
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Makes loud noise and doesnt heat. Timer, clock, turntable & other things work. Model # 665.61632100
Most likely the magnetron is bad. I'm guessing a household model. Unplug unit and unplug the connection at the magnetron and run again. The noise will likely be gone. If you do replace the magnetron, replace the diode that goes with it.
Sep 10, 2009 | Microwave Ovens
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
Lights up counts down and thats it no fan no spin no heating
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
Aug 13, 2009 | Zanussi ZM24ST Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
Microwave Ovens Logo
222 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
