Hitchens dvd recorder with a vcr manual E9G05BD. i need the manual part for settings to do the clock
eagle338
  • 4889 Answers
SOURCE: I need an owner's manual
Right-Click on this link and click save target as to download the complete owners manual
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2842852/dvr620_dkvr60_om_e.pdf
Posted on May 28, 2011
dodgecharger
  • 254 Answers
SOURCE: clock set and record time set
Check the model number, and then see if Sharp has a online manual. Some manufacturers have them available. Check here http://www.sharpusa.com/products/TypeManuals/0,1083,166,00.html Did you get a matching remote box with it? Most late VCRs must have the remote to do anything beyond basic functions. Certain universal remotes may have the necessary functionality.
Posted on Sep 10, 2007
SOURCE: Toshiba SE-R0128
Here's the manual:
http://www.fixya.com/support/p203786-toshiba_sd_v392_dvd_player_vcr_combo/manual-5746/
...starts at about page page 34.
Posted on Aug 29, 2008
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
SOURCE: Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Posted on Jan 12, 2009
I need a Hitchens HIT2737DVDRV manual
All the players i have used either have a set up or navigation or menu button. It should all be readable on the screen
Jan 26, 2015 | Televison & Video
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
WHEN I PRESET THE VCR TO RECORD MY SHOW LAST NIGHT 8:00PM IT WOULDNT WORK THE RECORD LIGHT DID NOT COME ON AT THAT TIME
There are a few things you must do in order to program a recording. One, you must make sure that the vcr clock is set. Two, the vcr must be set on the right date, as does the recording. Three, make sure that the daylight savings, AM/PM, etc. settings are saved accordingly. Also, if you have the operating manual for the vcr, you could check it for exact program instructions. I hope this helps, and I wish you the best of luck! Sincerely, Der Strom
Apr 13, 2010 | Philips Magnavox DVD/VCR Dual Player
HOW DO I SET THE CLOCK FOR SANSUI VRDVD4005, DVD-RW RECORDER & VCR
Found the manual here:
http://www.hammerwall.com/Download_Manual/9840/
enter the captcha code
then on the next page right click the MANUAL LINK, and choose SAVE TARGET AS to your desktop.
Setting the clock is on page 26.
Hope this helps.
Mar 25, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Need manuel for a Hitchens PDC Videorecorder (DVD-RW/R)
need manual for hitchens videorecorder dvd-rw/r
Aug 09, 2009 | Televison & Video
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Go into SYSTEM SETUP. thats where the clock settings are.
Mar 12, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
The clock on my VCR/DVD recorder will not keep the correct time. It goes back one hour repeadedly after setting.
You`ll probably find that the PDC (Program Delivery Control) is turned on. If you turn this off, the autmatic clock setting will be disabled and will have to be set manually. Ian
Jan 21, 2009 | Philips Magnavox DVD/VCR Dual Player
LG DVD Recorder- Clock settings Model RH277H
The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
Dec 28, 2008 | LG RH299 DVD Recorder/VCR
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
