Question about Xerox WorkCentre XD100 All-In-One Laser Printer
The Xerox Wokcentre XD100 is connected to the PC via a PCI to Parallel Card with it's original cable. The device manager has installed the card in LPT3 & that's the port used when installing the Printer driver... however when a document is sent to print a communication error returns or a "fail to print message" message shows on screen.
  • christoph42790 Mar 22, 2011
    The problem was solved by going into the Bios
  • Pendres Chekednes Sep 18, 2011
    What was changed in the BIOS to make it work?
  • 222 Answers
check printer port from printer "Properties" menu.
Posted on Mar 19, 2011
Prior to installing the radeon 4550 video card i followed the instructions and disabled the onboard video adapter via the device manager. I have the emachine model T6520. After disabling the onboard...
Hello
Try reseating the video card in the pci slot,remove completly then reinstall.
Also check your monitor video cable for being tight.
Last..Does this card require 24 volts? check for a 4 pin adaptor plug on the card.It may need its own power.
Apr 22, 2011 | E-Machines T6520 PC Desktop
Onboard video works fine but when I install a pci express card the video is garbled. The card checks out good on a different machine.
you need to unstill the intergrated vga port via the BIOS or disable the device via the device manager, install the new driver first the install the pci card
Feb 03, 2010 | E-Machines T6216 (827103077834) PC Desktop
Xerox Workcentre XD100 not printing
You need to use a IEEE-1284 Compliant parallel cable for this machine. A "changer" will not work, sorry.
Jan 25, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I have a cash management system Royal alpha
I find that a lot of serial to usb or parallel to usb converters do not work due to the fact you can't get bidirectional communication. In every case I have dealt with, the resolution was a dedicated port card to physically install a parallel or serial port in the system.
Dec 07, 2009 | Computers & Internet
XD100 Won't work with USB
check the usb port boot computer and printer..or parallel to usb or usb to parallell try it..
Sep 14, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Wireless PCI Adapter WPCI810GP
Hi, In your Device Manager, uninstall all instances of the wifi card, shutdown. Physically remove the PCI wifi cards from the motherboard. Reboot in Safe Mode. Verify that no wifi card is installed in the Device Manager. Power down, reinstall the Wifi Card, reboot, Windows should auto detect and auto install. You may need the original CD installer of the card, if not available, you need to download the drivers before uninstalling the card. As a precaution, use the features of System Restore. Hope this give you an idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 23, 2007 | Motorola WPCI810GP 802.11g/b (51803000100)...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
168 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
