Question about Thermaltake Toughpower XT 850W ATX12V EPS12V Power Supply (W0315RU)
All fans are spinning at full speed all the time.
    Guru:
  • 811 Answers
Greetings I personally like it when my fans are cooling at full speed all the time. That means it is cooling well. Now most computer fans are sensory thermostatically controlled fans. Which means they go on and off when the computer is cool and on when it gets hot. Now with this in mind. You may just need a simple blowing out of the hardware above the CPU might be packed with dust.
So first I would clean it out if you have not done so already if you have done so then I would go to control panel and click on the power options and set it to default. I noticed when I changed my settings away from default my fans stayed on. When I went back and set the power options to default the fans started going on and off during the hot and cold readings. This is just my computer efforts to solve this it is really not a problem if your fans are working full speed. However if you leave your computer on all the time note that this will wear them down sooner than they would if they were going on and off. Thanks for using FixYa! John
Posted on Mar 19, 2011
Upon starting my truck I hear the sound of rushing air for about 30 seconds then ok; why?
I would say more than likely it the radiator cooling fan. For some reason some vehicles, no matter what temperature, the cooling fan clutch engages which makes the cooling fan run at full speed like there's no fan clutch.
It sort of makes it sound like the engine is revving up but it's simply the sound of the rushing air from the fan clutch making the cooling fan spin at full speed.
Hope this helps.
Feb 21, 2015 | 2001 GMC Sonoma Extended Cab
My Acer Aspire desktop computer CPU fan runs at full speed constantly. Only hours after setting it up for the first time straight out of the box, the fan suddenly kicked into full gear, desperately trying...
Try going into BIOS menu and look at the CPU tab and probably inside it you will find everything about the FAN.(or any where near it, since you gave no info about mother board / BIOS
The reason why its spinning at high RPM is because,
a) Its been set to TURBO
b) Its been set to Manual and @ high RPM
Oct 24, 2013 | Acer Aspire M3900-U4002 Refurbished...
I have a variable speed wall switch on my ceiling fan. It is made specifically for fans. Problem is it doesn't work. If the slider is full on the fan spins. If I unadjusted the slider the fan turns...
If the wall switch doesn't have 3 or 4 speeds then it is not a fan control. There are no fan companys that make a variable fan control so that should tell you something.REPLACE IT with a fan control.
May 28, 2013 | Dryers
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
Hi, for some reason, after Windows 7 has loaded the fan stops spinning on the Ageia PhysX card. The fan also makes a weird noise which it never used to do. Do u know what's wrong with it? It's...
In BIOS the fan always runs at full power, in Windows the speed is supposed to be automatically adjusted, depending on how heated the processor is. In your card it appears that the fan is dying, no longer capable of running at anything but the full speed. You will have to replace it - follow this
http://www.squidoo.com/video-card-fan-replacement
May 22, 2011 | BFG Technologies AGEIA PhysX 128MB GDDR3...
My cooloing fans are running full speed all the time which is very loud and annoying. how can i fix this?
Firs thing you need to do is to find our why they are running full speed. My guess is that your computer is dirty inside and it is overheating, thus causing the fans to run full speed trying to cool it off. Disconnect everything from the pc and take it somewhere to clean it out. Remove the side panel an use a can of compressed air or an air compressor to blow all dust out the interior of the pc. Pay close attention to the heat sink on the processor and the cooling fans. When blowing around the fans hold the fan in place with a pencil to prevent it from spinning as this might damage the fan. You need to clean out the inside of a pc sitting on the floor every 6 months. If you have cats or dogs that shed living inside then every 4 months. If it is sitting up high and you have no animals then every year may be good enough.
Oct 05, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
Turn on computer power up fan spins fast monitor
Here is some diagnostic information. The Fans running at full speed are an indication of a NO POST failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 17, 2010 | Dell Inspiron 530 Desktop Computer
Heater fan dont work all the time on my 94 volvo 960
After some years, the the filters (made of foam) in the HVAC system can become dry-rotted. Debris from the rotted foam, as well as dust, can accumulate in various places within the system. Unfortunately, the motor housing of the blower is one place in which the dust and debris accumulate very well. To fix the problem, you have to remove the cover from the blower, and vacuum clean it. The blower is behind the glove box, on the lower right side.
A word of caution: The fan cage (which looks like a gerbil wheel) can become brittle, over the years. After cleaning out the blower motor, the blower will be able to freely spin at full speed, again. This may be too much for an old brittle fan. If your old blower can't take the force of spinning at full speed, you will hear it break apart inside its chamber. I discovered this, the hard way. After cleaning the dust and debris from my Volvo's blower motor, the blower spun at full speed and the fan broke apart. So, I had to buy and install a whole new blower.
Dec 13, 2009 | 1994 Volvo 960
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Thermaltake Toughpower XT 850W ATX12V  EPS12V Power Supply (W0315RU) Logo
71 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
