HP Deskjet 3845 does not stop printing
My printer does not stop printing. I am running out of paper. I have cancelled several times. Having problems getting Alt Print repond to give me the print page. What do I do?
I changed to Microsoft Word , where I could get the print page and there cancel the printing gone wild.
Ib Barfod
Posted on Aug 03, 2008
Hp deskjet 3845 printer will not print and it is no paper jammed, it is installed properly
it sounds like your printer is not connected to the pc or laptop,check the USB cable properly.another problem is paper jam or which leads to qeueing of docs to be printed.
Mar 01, 2013 | HP Deskjet 3845 InkJet Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
I cancelled a printing sheet of paper and now it won't print anything.
Did you try turning off then back on or unplugging it and plug it back in. Open up your printer folder and clearing all documents?
May 01, 2010 | HP Deskjet 3845 InkJet Printer
My hp deskjet 3845 is not printing, it says there is a document printing but i have cancelled all documents - any ideas?
Hi Jamie,
You best option is to reset the printer spooler. 1. First turn your pritner off. 2. Then in you PC, click on "start". 3. go to "run" 4. type in: CMD 5. This will bring you into a DOS window.. In the DOS window type: net stop spooler (press enter) 6. now type: net start spooler (press enter) 7. now type: exit (press enter) 8. Now turn on your printer.
This should have rested the printing system.
Regards, Ed
Nov 21, 2009 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
Printer won't stop printing garbage
Try and re-install your printer drivers...first remove the drivers and delete the printer...then re-install.
Dec 03, 2008 | HP DeskJet 812c InkJet Printer
Printer is not printing at all
You may not install the correct driver for the correct OS. Not sure what OS you are using but below link might be useful for you to get the correct driver and install into your PC.
http://etech.maiila.com/hp-deskjet-3845-driver-manual-software-download-and-troubleshooting-tips
Hope this helps
Nov 13, 2008 | HP Deskjet 3845 InkJet Printer
Paper jam
Check for anything small stuck between the rollers, like a tiny fragment of paper, or any other debris. Clean it with a can of compressed air, if possible. Hold the printer upside down and gently try to shake off anything that may be inside. Sometimes you may have to dismantle the cover to check properly.
Clean the roller with a damp cloth and wait for the rollers to dry completely before trying to print again.
Make sure you have selected the correct paper type and quality from the printer properties.
Jun 02, 2008 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Dec 09, 2007 | HP Deskjet 3845 InkJet Printer
123 people viewed this question
jasbo
jasbo
