Hi , i managed to install primevera P6 into my windows 7 . When i log in , it prompt me a message "licence file is not valid for this version, please contact your supervisor" . Any idea to solve this issue . Thanks
    Guru:
  • 811 Answers
The only thing I can suggest is contact the administrator if necessary or get a valid license by purchasing the software or calling tech support to get you one. Without the valid license basically you cannot use this software or program. Thanks for using FixYa! John
Posted on Mar 19, 2011
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
How can I check if my current Licence has expired?
I am not sure if I understand what you want to know, because the licence number of Avira actually has nothing to do with logging on a saved file.
Open the Avira configuration.There you will find how long your licence is still valid .In case it has expired you would have gotten a message from Avira, a pop up, asking you if your want to prolong/buy a licence.
Oct 03, 2014 | RTO Avg Anti-Virus & Anti-Spyware 8 for...
I can start my Primavera P6 with OS windows 7, I use P6 stand alone. database configuration said ''Bad public user name or...
The standalone DB Configuration seems simple but can be tricky When you configure the DB you have to use a Coded Username for the AdminSuperuser permissions "admprm$pm"! this user name makes your actual Log in username "Admin" you cannot use the admprm$pm at the Log in screen. Same with the Public User Permissions "pubprm$pm" gives read permissions but log in user name is "Public" Try the "Admin/Public" usernames if this does not work you may have to Uninstall and Reinstall. If you uninstall remember there are 2 peices of software to remove... P6 and the Oracle Database 10G
Refer to: http://www.tensixconsulting.com/2013/03/primavera-p6-database-connection-configuration-details/ For further DB Config Issues.
Mar 25, 2013 | Primavera Contractor 6.1 Full Version for...
I just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect
You must connect to a database to utilize Primavera. You can not bypass this portion. So, Either remove the Database and reconfigure, or in the "Configure" Screen you can Name a new DB and use it. I would suggest that if you do not require 2 DB's not to have two. "The Oracle Database 10g" application that is installed with P6 (In your 'All Programs') will give you some DB manipulation options. Other wise refer to the TenSix link to clarify DB Config
Feb 13, 2013 | Primavera Contractor 6.1 Full Version for...
Win 7 install prob
Hi, I suggest to plug in the Internet LAN cable, Boot the Windows Disk setup. When installing, the missing Drivers for your Hard disk will be detected and installed automatically using the Internet.
If that wont help, I suggest you use another CD / DVD that has a recent version of the Windows you want to Install.
Good luck
Jun 26, 2012 | Computers & Internet
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
I have problem with my desktop.
Try to follow some of these methods:
First Method
  1. Lauch Windows Task Manager.
  2. End wgatray.exe process in Task Manager.
  3. Restart Windows XP in Safe Mode.
  4. Delete WgaTray.exe from c:\Windows\System32.
  5. Delete WgaTray.exe from c:\Windows\System32\dllcache.
  6. Lauch RegEdit.
  7. Browse to the following location:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
    Windows NT\CurrentVersion\Winlogon\Notify
  8. Delete the folder ‘WgaLogon’ and all its contents
  9. Reboot Windows XP.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
Second Method
Another alternative suggested by dman is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Note: Again, you may be prompted again to install WGA Notification, so it must be bypassed.
Third Method updated
This method involves using a cracked version of LegitCheckControl.dll to replace the original copy of LegitCheckControl.dll, and thus bypass the WGA validation and make Microsoft believes that your copy of Windows is genuine. To get rid of WGA Notifications warning messages, the patched version of WgaLogon.dll and WgaTray.exe to replace the existing files.
To apply the patch by replacing the files manually, try to end the respective processes in the Task Manager before deleting the existing files. Most likely is you will have to restart your PC in Safe Mode in order to replacing the original copy of LegitCheckControl.dll and related files. However, there has been automatic updater and even cracked WGA installer that automatically apply the patched version of WGA files.
Latest Update for WGA version 1.5.708.0 latest
Download cracked and patched version of LegitCheckControl.dll with thanks to Danny.
Latest Update for WGA version 1.5.554.0 latest
Download cracked and patched version of LegitCheckControl.dll, WgaLogon.dll and WgaTray.exe for v1.5.554.0 of Windows Genuine Advantage Validation Tool and WGA Notifications.
rate me if this works.
Mar 22, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
