Question about Microsoft Select Application Center License and Sofware Assura (D93-00164-2) for PC
How to get turbo c full screen in dos box...i use windows7- 64 bit...plz solve my query
    President:
  • 1,216 Answers
Alt+enter
Turbo c/c++ is not compatible with windows 7 at all.
changing compatibility will only allow you to use it without the graphics library so.it's no use at all.
What experts generally suggest is using software virtual PC and install XP with it so that when you click the virtual pc you switch to xp and it's job done
Posted on Mar 19, 2011
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
I have a windows 7 or windows xp both in one computer . when i am install turbo C soft ware in window 7 it doesent open full screen in window 7
turbo c will not open in full screen on windows 7 neither graphics will work
so either u have to use dos box and mount turbo c on it or use some other compiler
Nov 20, 2010 | Computers & Internet
Turbo c is not working in full screen in windows 7. Please let me know if you know the Soluation.
Vista and upwards do not support full screen for DOS applications. If you need to use it in full screen mode, use DOS BOX. But it will crash if you perform pointer or memory based operations.
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
Turbo c/c++ not working in full screen mode
uninstall u r graphics driver and then reinstall a updated version of u r graphics driver.
Sep 03, 2008 | Intel Motherboard
The problem the dos is not compatible with windows xp.Right the launcher file and select properties->screen->select window(i.e deselect full screen) now the program will launch hopefully,it worked for me. now go to full screen by pressing alt+enter.
Aug 20, 2008 | Dell Inspiron 1501 Notebook
Turbo c doesnt have a full screen version on vista..
FOLLOWS THESE STEPS TO SOLVE THIS PROBLEM...
  1. Copy the “DOSBox0.72-win32-installer.exe” from http://www.download3k.com/Install-DOSBox.html
  1. Install it with default settings.
  2. Create a folder “Turboc” in your C:\> directory.
  3. Copy your turbo c folder such as “TC” in the folder “Turboc”. This is shown in the following diagram.
fifth.jpg?w=625&h=526<!Run the software you installed. Its icon is present on the your desktop.
  1. This will run the software, as shown in the fig:
first.jpg?w=573&h=507<!
Write these lines in the screen:
mount c c:\>Turboc
Press Enter
Following message will appear on the screen
Drive c is mounted as local directory c:\Turboc\
Now write:
C:
Press Enter
Now write:
cd TC
Press Enter,
Now write
cd bin
Press Enter,
Now write
Tc.exe
All these steps are shown in the following figure:
8.
Now following screen will appear:
10. Press Alt + Enter. Full screen mode of Turbo C will appear.
[updated]IMPORTANT : Don’t use shortcut Ctrl+F9 bcoz it is a shortcut for dos box to exit
Happy Coding
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
go to compiler set it into ur drive where it belong ur C++/ turbo
May 16, 2008 | Microsoft Windows Vista Ultimate Edition
Looking for a vista compatible c/c++ compiler
As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) nd not at all suportable by 64 bit vista. to install u have to install the display drivers of XP, that can be found at the site of the manufacturer of ur Laptop/PC(in some cases graphics card manufacturer). All the best...., further having any query , pLz fell free 2 ask
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
176 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
