Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquariu 900 keeps tripping electric. I have changed fuse in plug but it still trips
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. We would need to know exactly at what point in the programs it does it ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Also as a help for the future there is no need to change a fuse if it hasn't blown ;-0)
Sorry again and good luck,
John C
Posted on Mar 19, 2011
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Hotpoint model 6671P convection microwave keeps tripping mains panel Fuse when start is pressed. Could this be a problem with a fuse in the Microwave or is is a dud magnatron? How best to test?
Too many watts on same circuit. Plug it into a different outlet and see what happens, not on same circuit. So one that stays live when micro trips circuit breaker.
Mar 05, 2015 | Hotpoint Microwave Ovens
Hi. I have a hotpoint ud47i fan assisted oven which keeps tripping the oven related fuse box. Can't find any obvious faults. Strange thing is that once I reset the fuse box, the oven works again for 5-10...
The oven is tripping the circuit because it is pulling to many amps.
Best thing to do is get an electrician to install a larger amp circuit for you. This will fix the problem and should be cheaper than another stove.
Mar 27, 2011 | Hotpoint Microwave Ovens
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint tcl770 condencer tumble dryer, just out of warantee. when turn on and start it keeps tripping the electrics. changed plug fuse etc, tried in various sockets but keeps tripping the system???
internal problem, either heater coil or sensor or motor, you will need to get it checked, but don't plug it in again, as short circuits on high current machines can be dangerous.
Jan 14, 2010 | Hotpoint Dryers
Hotpoint Aquarius WM31 Washing Machine
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Aug 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WMA42 Front Load Washer Logo
129 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
