Question about DeLonghi KG79 Grinder
My DeLonghi KG79 coffee grinder has stopped working after one grind. When the on button is pressed nothing happens. I tried changing the plugs fuse... any thoughts? cheers Kev
I should imagine one of the safety switches are not closed. The lid of the maker must be on and the filler has to have its cap on and inserted in the machine.
Posted on Aug 08, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Stopped grinding beans, no action when I press the grinding button
Hi, your grinder needs to be replaced. Its a pretty easy job. The grinder comes as a full assembly, new cutters and all. dazza
Oct 13, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
No water is pumping thru the water spout or the coffee spout, the machine is reading fine grounds and press okay for water. i've adjusted grinder dial and pressed water button but nothing happened
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Sep 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Grinder setting jammed won't turn
HI
When making adjustments to any grinder it should be grinding at the time. Rotate the adjustment setting to a larger number, say 10 an try again. Then if it starts, turn it down to the number you want.
Nov 05, 2009 | Pasquini GMSC Electric Burr Grinder
My Saeco magic deluxe needed the circuits relaoded. I followed the intructions and now my machine tamps first and then grinds the beans leaving me with weak coffee can anyone solve this for me ?
try this.
hit the external dosage button. Its the button on the top middle that controls when you want to put grinds in from the external shoot.
Do not place any coffee in there. then just press the normal brew button. it should brew more or less a cup of water.
then try brewing a coffee like normal and see if the problem fixes.
this happens because there is a little door in the grinder that hits a microswitch that tells the grinder to stop grinding.
This is supposed to happen when the grinder fills the brew group enough to click the microswitch.
Sometimes it does reverse itself like this.
The only other solution would be to open the grinder up and vaccum all grounds out and vaccum the grind shaft above the brew group on the side.
This will cause the door to go back to normal position.
If it doesn't work after that, the door or microswitch has gone faulty. But that is an extremely rare situation.
Hope this helps.
Oct 03, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
DeLonghi KG79 Grinder Logo
1,213 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
