Ho i have a hotpoint wma60 and it wont spin. can you help? thanks jo
    Brigadier General:
  • 6,277 Answers
(try this first!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 19, 2011
Hotpoint ultima washing machine wma60. Bought new belt but can't get it on
(extract from my general guidance notes for replacing belts.)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 13, 2011 | Hotpoint Washing Machines
Woh kaun sa fruit hai jo kacha ho meetha aur pakka ho kadva lagta hai
WO KAUN SA FAL HAI JO KACHA HO TO MITHA LAGATA HE AUR PAKHNE PAR KADAVA LAGATA HE
May 20, 2011 | GPS
3230 me 1,6,8 keypad nahi work nahi kar rahi hai
  • are yar keyad work nahi kar raha hai to sabse pehle uska front bord jo keypad belt k sath laga huwa hai use check karo
  • or uske bad keypad belt change karo lakin wo hard hai so ek hi solution hai koi dusra front bord change kar k dekh lo
  • is se 100% ho jayega ok
  • nahi to key pad ic change karo
  • ok
  • my name is
  • IDRISH 911
  • IDRISHANSARI28@YAHOO.IN
  • KOI BHI PROUBLEM HO TO AAP MUZE PUCH SAKE HO OK
  • FRIEND
  • BYEEEEEEEEEEEE
Oct 25, 2010 | Nokia 3230 Cellular Phone
Spiderman 2.55 se china phone start hoga kya jo switch off ho gaya hai...plz guide me mera china phone off ho gaya on nahi ho raha hai.
teri phone me IMEI number hai kya ?
sare phone jo China se hai aur jin me IMEI number nahi hai vo sab mobile network se nikaal diya gaye hain Dec 1 tarik se...
Dec 21, 2009 | Handmark Software MobileLists (950142) for...
Mera mobile china ka hai jiska imei no hai 356800805072256 mai jab *#06# par karti ho to us par massege aata hai imei 356800805072256 imeisv78 imei 135790246811220 aap plz meri madd karo
dear.....jo imei app ka phone show karta hao wo sahi hai.jo box pa hai wo ghlat ho ga........take my num for more help...if u r frm pk....0345-7222471
Nov 14, 2009 | Lands Phones
My i-mate mobile phone is dead condition
Vinod Agarwal, aapne farmaya ki full charge battery par hi chalta hai aap ka phone. agar aisa hai to new battery kaistemaal karo. Agar phir bhe dead hai to kriya karm kar do choonki aap ka phone saal bhar band raha aur ab aap us ko daurane ki koshish mein lage ho. Itne waqt me to aadmi bhi mar jaata. kripya battery badlo to shayad chal jaaye.
Sep 10, 2009 | i-mate JASJAR Cellular Phone
Will not spin.
could be a couple of causes.First take off panel at back of machine and check that belt is in place.
Has it been noisy on spin lately?
Jan 29, 2009 | Hotpoint WMA64 Front Load Washer
User manual required(hotpoint ultima wma60)
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
If your number is not above click on Hotpoint.
Rate me pl if helped...................
Mar 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
