Question about Canon PowerShot A520 Digital Camera
When start the camera following error occured 'Chang the batteries' what are the solution for this problem
    Master:
  • Canon Master
  • 443 Answers
The baterys may need to be replaced with new batterys from the camera place neer you
Posted on Dec 25, 2011
I have a ricoh 500G caplio camera stuck in play back, I push the Green Arrow as per the instructions, but it will not switch back to the shooting mode.
When an error occurs with a digital camera, try switching it off. Wait till no light is burning or flashing and then remove the battery (batteries when there are more) Leave the battery out for a few seconds and reinsert the battery. After switching on, the camera should work normal. But if the error comes back, you should contact a service centre of your camera brand and make an appointment. (Or you could start looking for another camera?)
Jan 31, 2014 | Ricoh Caplio 500G Digital Camera
My GTB 5722 haddset Camera Not working IF i Start Camera isee a massage preview error
i thing camera no conect with bord open the phone and fix it again or chang it
Feb 26, 2012 | Samsung GTC3300 Cell Phone
Nikon coolpix l21 camera lens error.
I have the identical camera. A camera lens error may occur for the following reasons;
a.) check your battery. Use the recharger wall set to charge the battery and then try your camera.
b.) lint, dust or greasy materials like skin oils and lotions may be clogging the mechanism allowing the lens to move. Clean it carefully with a cotton cloth and a TINY bit of isopropyl alcohol. Don't use a cotton swab because fibers from them are nearly as bad as the dust or lint.
c.) the camera may have been dropped and the mechanism actually broken. I cannot help you there.
Try the first two solutions and remember to comment if they are helpful, please.
Have fun taking pictures!
Sciencewoman
Apr 01, 2011 | Nikon COOLPIX L21 Digital Camera
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
I have a camera it's a canon S5 IS i let a friend borrow it he dropped it and now the lens won't go back in it says lens error restart camera i need help
Lens error occurred due to external shock, Now lens is prevented from properly extending or retracting.
1) Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
or..
2) Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
  • Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
If this will not solve the problem your device need service (repair)
Rating the solution in highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot S5 IS Digital Camera
Error message "unknown error has occurred"
how to transfer picturesd from digital camera to pc just watch video
Jan 07, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Error code 22
ERR 22: CF DRIVER
DESCRIPTION: This error occurs when image data cannot be written to the CF card. This error can occur when the CF card is not fully seated in the camera or if the D30 does not detect a card-ready signal within a specified time limit or when the CF card is not usable because it has been corrupted or physically damaged. It can also occur when the camera's battery level is insufficient to completely write the file to the CF card. REMEDIAL MEASURE: Use the DC Coupler or recharge the battery first. If the error continues to occur with sufficient power available to the camera, check that the CF card is properly inserted. If that's not the problem, then try replacing the CF card. If that does not solve the problem, have the EOS D30 and one of the CF cards that is causing the problem examined by a qualified service technician.
Got this from here: Digital Outback Photo
Feb 09, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Canon PowerShot A520 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
