What does dtv stand for - Televison & Video
  • 718 Answers
Dtv
Digital Television.
The signal is transmited in 1s and 0s in the form of packets. The old analog system is sent in the form of radio frequencies.
Posted on Mar 19, 2011
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Tip
Making the ebox a stand alone system to work with any tv
I have place this info on another site so I'll give you a link ,by making the ebox a stand alone unit most of your problem will be resolved because the ebox will no longer look for the Philips tv signal .
You must have a remote control for the ebox to make this work ,I hadv had my ebox hookedup to a regular computer LCD screen for 4 years and neve had any problems with it since the ebox was change over to a stand alone unit. Here the link good luck
http://www.lumenlab.com/forums/index.php?showtopic=13973
on Mar 03, 2009 | Philips E-Box FTR9965 DTV Receiver
Our Mintek HDTV Mod# DTV-323. WIth an internal DVD Player keeps comming on when it is in tv mode. there is a disc hung in it. It has not worked for a long time. How do I fix this problem or can the dvd...
2 answers 1 usually you can remove a stuck disk by finding the tiny pin hole on the dvd insertion tray and pushing it in about 1/2 inch this will force open the player so you can remove the stuck bootleg dvd you put in it. step 2 is you can unplug the tv lay it face down and remove the stand and the back screws from the tv there about 20 screws once removed you can pll the back off the TV and find the dvd module and carefully disconnect the moduler plugs connected to the dvd
Feb 20, 2018 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Goodmans LD3265D1 TV won't switch on.
use a freeview box, turn the dtv off in the menu
To get it too power on press the source button a lot after a (good) few trys your get it up on another source, my own tv does this and using a freeview/freesat box makes it use-able just a pain to turn on in the first place even if you turn the dtv off in the menu
If anyone knows how to get it to turn on stright to another source would be great to know how
Mar 31, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
How to Enable inactivity standby on dvr
You must go into the menu and select preferences and inactivity stand by.
From there you will select the time frame you desire or turn it off.
Thanks for using Fix Ya.
Mar 14, 2010 | DISH Network DVR-625 DTV Receiver /...
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Tivo
You can use SATELLITE and CABLE at the same time which involves DIPLEXING.but if you do not have satellite service then ,NO.You cannot use the TIVO functions with cable.However you can have a stand-alone Tivo that is specially made for either cable or satellite.Try reading up on the Standalone Tivo's perhaps the have a Tivo 2 stand-alone now.If your really lucky there might be a hack for the mod you are wanting.Try http://www.dvrupgrade.com/dvr/stores/1/ you might get lucky.
Nov 11, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
