Question about Bronica RF645 Medium Format Camera
Hi, bronica rf645, problem with the film advance, the film advance mechanisme don't lock on the 1 exposure , the shutter release button don't work X in the finder, you can advance the film to the end .When the film type selection level is in position 220 instead of 120, it seems work for one or two exposures. Regards A.B
  • 36 Answers
SOURCE: 120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Posted on Jan 26, 2008
fotobean
  • 103 Answers
SOURCE: Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
Posted on Jan 21, 2009
SOURCE: My RZ67 (with new battery, lens correctly mounted
Needs film in the filmback works fine. With no film will only work in M mode (multiple exposure)
Posted on Oct 17, 2009
  • 68 Answers
SOURCE: Just starting out with medium format. We bought a
Sounds like a problem with the single/multi "switch".
Film should not wind on in "multi" setting.
Back to the dealer - if he is reputable, he will get it fixed.
Posted on Dec 27, 2009
  • 102366 Answers
SOURCE: Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Posted on Apr 11, 2010
Zenzanon 80
The lens does not have a shutter - that's in the camera body. The lens contains the aperture or f stop adjustment. It is done by injecting or retracting blades in the light stream of the lens barrel between the front and rear optics. Check the aperture blades to see if they move easily and open equally by varying the f-stop ring on the lens while looking through it. If not moving all the blades the same amount or it does not continue to restrict the opening as you increase the f-stop value, there's something wrong with the lens.
Are you sure you haven't accidentally activated any exposure compensation adjustment on the camera body?
Jan 10, 2012 | Bronica 80mm f/2.8 Zenzanon-PS Lens
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Loading film
After further investigation and because I can't keep my hands out of things I now know that the camera body is defective and that the shutter is jammed. It will only release with assistance. I was loading it correctly.
Apr 17, 2008 | Photography
120 film backs
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Bronica RF645 Medium Format Camera Logo
138 people viewed this question
Top Bronica Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bronica Photography Expert? Answer questions, earn points and help others
