Question about Speed Queen AWS75NW Top Load Washer
Does not want to drain the water after washing circle
  • Speed Queen Master
  • 19,396 Answers
Hi.
Start checking the drain hose at the back, and the hose attached to the drain pump, located at the bottom of the appliance. After that access the control panel and clean the hose attached to the pressure switch. Also check the lid is closing well. Those are the only easy fixes.
The first parts to check are door latch and drain system.
The timer performs an additional check on the door latch before advancing to spin. The door switch it is tested by jumping its contacts, or by reading impedance to check if the switch is opening and closing the circuit (you will need a multimeter).
About the drain system,
if the machine does not drain, then the cycle will not advance to spin.
The electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle. If there is a drain problem, then the machine will not spin.
The first step will be accessing the drain pump.
Kenmore top loaders' washer pump is accessed from the bottom side of the appliance.
Get ready to collect the water that will come from inside the tub.
Check also the drain hose at the back. Ensure that the height of the hose elbow is respecting the specifications indicated in manual. A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Enter full model number here (the one written on tag) to get all parts and diagrams for your washer.
Regards.
Ginko.
Posted on Mar 19, 2011
Drum not spinning
Check the drain pump, look for debris. have a shop vac and some towels, also unplug it for safety. Access the drain pump on the front lower right corner. Bosch washers usually have a panel that is circle shaped. stick a paper clip in the little hole and rotate the circle counter clockwise. From there, the drain has a cap that can be unscrewed off. water will come out, so have a shop vac and towels handy. remove all the bad stuff that shouldn't be there. Usually you will find change.
Sep 19, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer code eo4
Being a drain issue , you need to remove the drain pump, check the filter and also check on the outlet , click catchpot
Jan 20, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Our washer is not draining. It said, "suds or not
Check your pump for foreign objects. The pump is right behind the circle on the front of your washer. Take the circle off and you will see it. Unscrew the front of the pump and pull out. This is a trap to collect objects so they do not get caught in your pump propeller. CAUTION! If your washer is full of water be sure to have buckets and rags ready because all the water in the machine is going to come out
Jul 11, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
WATER NOT DRAIN OUT, MACHINE NOT MOVE TO THE NEXT STEP AFTER WASH, NOT RISING, NOT SPIN NOT COMPLETE THE FULL CIRCLE... CAN IT BE FIT PLEASE & HOW?
first check the drain on the washing machine to be sure it is not clogged. if not then the problem could be your pressure switch. if you have a multimeter use it to check for any electrical issues. if there is no reading the pressure switch needs to be replaced.
Feb 04, 2011 | Whirlpool Washing Machines
Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Machine doesn't discharge fully
check that the out let pump filter is clear first,, then check that the drain pump is working,, it may be blocked up or stuck so it cant turn or maybe the drive motor has burnd out or the drain away pipe could be a little blocked up
Jul 01, 2010 | Indesit WA 125 Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I have a Hoover 750L washing machine and it is not spinning now in the washing circle so the clothes are soaky wet. How can I fix this problem
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
Mar 31, 2010 | Washing Machines
What does it mean when the washer says oe or ie
The "IE" code indicates a water inlet problem. This code is generated if the correct water level isn't reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. I would look at the water inlet valve first regarding this code. Unplug the machine, shut off the water and remove the supply hoses. Check the small metal screens inside the valve and make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid. I'll attach a photo for reference.
The "OE" code indicates a drain problem. This code is generated if the water is not fully drained within 10 minutes. Check the drain hose for kinks or obstructions. Sometimes running a hot wash cycle with about a 1/2 cup of vinegar will clean out any sludge buildup in the drain hose. If this doesn't correct the problem, then the next thing to check would be the pump. I sure hope this helped and best wishes.
Sep 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water remains in the drum (Maytag washer).
NO, there is a small blockage within the drainage system. check the following to combat this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Speed Queen AWS75NW Top Load Washer Logo
273 people viewed this question
Top Speed Queen Washing Machines Experts
Charles T Nevin
Charles T Nevin
fta777
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
