Question about Amana Dryers
My gas dryer's igniter glows, but gas valve does not open. this occurs up to three tries. there is no schematic to be able to test and isolate problem. Is there a schematic available for Amana LG8319W2 Serial #S9605040810 ?
  • 958 Answers
Im sure the theory would be the same as the whirlpool, in the whirlpool, they have this flame sensor, if it senses the heat from the igniter, the it would open the solenoid valve to release the gas to ignite and hold it open as long as there is flame present.
it could be a defective flame sensor.
cheers,
drcool
Posted on Aug 02, 2008
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
Model 110 72712101 kenmore gas dryer will come on run about 2to3 minutes then goes off after a short the glow will come on again but will not relight.
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Here is a link to the parts you need.
Jan 02, 2011 | Kenmore 63942 Dryer
Model LG8219W2 On initial start up igniter turns on and flame is ok, after heats up and cycles the flame does not reignite,I can see the igniter glow red but flame does not return. the igniter contiues...
HI. This will essentially be an issue that concerns the gas valve coils. With that said, I will post below a complete burner assembly procedure that will help you isolate the culprit. I'm sure that the coils will fail the test, but to be safe, follow the procedure to confirm.
Gas valve/Burner testing procedure:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Click Here to access a exploded diagram of the burner assembly. The affected coils will be labeled number 15 and 10. The actual coil and valve assembly will be labeled number 11 and the burner will be labeled number 9
Aug 22, 2010 | Amana NED7200TW Electric Dryer
The igniter glows but it wont heat
The burner power circuit is good as indicated by the igniter glowing. The problem now lies in the gas valve solenoid coils failing to open the valves to allow gas to flow be ignited. The coils are located on top of the gas valves one with two terminals and the other with three. Replace both coils to make the dryer heat up again.
Aug 02, 2010 | Kenmore Dryers
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My GE Dryer, model number Model# DSXH43GV1WW doesn't heat up anymore. The dryer turns on, the drum spins, in all the three types of available cycles, just no heat at all. Any ideas?
First make sure that the gas valve is on. Then verify that the gas connector is not kinked or restricted. then remove the connector at the back of the dryer and make sure there is gas pressure. Then visually inspect the pipe at the back of the dryer. Use a flashlight to inspect inside the pipe and make sure there is no debris inside the pipe that could restrict gas flow. On this dryer there is no removable burner door cover on the front or inspection window so you will need to remove the back panel of the dryer. Once the panel is removed you can turn on the dryer. You should first hear a click sound. That is the first gas solenoid valve opening. Then the igniter should start to glow. Once the igniter reaches 2200 degrees the secondary gas solenoid valve should click and the burner will come on. If you do not hear a click when the dryer is first turned on you will need test the first gas solenoid valve. Make sure it is getting voltage with a fluke meter. You can also touch a piece of metal to the top of the valve and the top should be magnetized when active. If you hear the first click but no igniter glow then verify the igniter is getting voltage and test the igniter with a fluke meter. You will need to test the ohms and most should be 500 to 700 ohms. If the igniter does not get a good reading or none it is probably defective and needs replacement. Usually most places that sell appliance parts will test the igniter for free. Just because the igniter glows does not mean that it is good. It can glow but not reach the 2200 degrees needed for the proper operation. Now if the igniter is good and you hear a second click then there might be a restriction somewhere in the gas line between the solenoids or the gas orfice at the burner. The sensor Gort was talking about is the flame rectification sensor and can detect the flame. It is rare for this to be faulty but not impossible. If you get flame for a couple seconds and then it shuts off it could be this sensor. Blow the burner assembly and this area off with compressed air and lint can block the sensor's ability to detect the burner flame. Also I believe your dryer has a larger fan blower than standard dryers. If this blower motor is not working the rest of the system will not come on. make sure the assist fan is working and that the vacuum switch is working and not stuck. Also check the vacuum line is not disconnected or restricted. And always remember that there are exposed power connections inside the dryer that could shock you and cause injury. use caution and if you do not feel comfortable working on this you might want to call a professional.
Sep 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Gas Dryer igniter glows but does not ignite
If the igniter goes on but only cycles off you have a bad solenoid coil on the valve you can pick them up as a set at a local parts supply shouldn't be more than $25
Sep 04, 2009 | GE DDC4500S Gas Commercial Dryer
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
Whirlpool dryer will not Let gas through Valve...
Look to see if the igniter glows while trying to ignite. You can open a rear panel on the back of the dryer and see if it glows. If not then the igniter may be the problem. Try that first and let me know the results. Thanks Sea Breeze
Jul 24, 2009 | Whirlpool Dryers
The drier is working but there is no heat. This occured about a month ago and the service man came out, replaced the filter (which was worn down partly due to using drier sheets) and unclogged the vent...
hi..
Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow. If all the controls are set correctly on the front control panel and the dryer is running, but the glow coil fails to glow, you've located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. The nut on the gas valve to remove it from the gas supply pipe turns counter clockwise. There will be small sheet metal screws used to secure the plate to which the burner assembly parts are attached. The plate holds the entire assembly and is attached to the bottom of the dryer's cabinet.
Next, remove the glow coil from the burner assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil. Glow igniters are fragile and they break easily. Handle and install the new igniter carefully. Glow igniters are a non-returnable and non-refundable electric component.
Be advised that some new replacement igniters do not come with quick disconnect ends. In this case, it is OK to cut off the quick, disconnect from the old igniter and attach it to the new igniter. Simply clip off the wires several inches above, disconnect the old igniter, attach to the wires of the new igniter, and wire nut the two ends together. Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative polarity to be concerned with.
Jul 08, 2009 | Fisher and Paykel Dryers
Dryers Logo
152 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
