Question about Eclipse Car Audio & Video
Reconnecting the battery after installation of the amp
  • 56 Answers
Red on + Blk on - in that order otherwise you could shock yourself, pop the inline fuse, or damage the AMP.
Posted on Sep 15, 2011
How to change the 80 amp fuse on my 2007 pontiac torrent awd
Not sure if it's any different than the 2007 Pontiac Torrent 2wd, but if it's the same you simply disconnect the battery, and the 80 amp fuse is attached by two bolts located right next to the positive terminal of the battery. Make sure you do not reconnect the battery until after you install new fuse.
Aug 30, 2012 | 2007 Pontiac Torrent AWD
Remove starter 2001 Lincoln Town Car
Print
Removal & Installation
  1. Remove or disconnect the following:
    Negative battery cable and properly isolate to prevent accidental reconnection Red solenoid safety cap Wires from solenoid 2 upper bolts 1 lower bolt and starter
    Fig. Starter motor mounting
To install:
  1. Install or connect the following:
    Starter and lower mounting bolt 2 upper mounting bolts. Tighten all 3 bolts to 15-20 ft. lbs. (20-27 Nm). Wires from solenoid and tighten the nut to 40-50 inch lbs. Red solenoid safety cap Negative battery cable
Aug 15, 2012 | Lincoln Town Car Cars & Trucks
How to replace a starter
Starter - Removal & Installation
To install:
Hope helps.
Aug 02, 2010 | 1999 Lincoln Town Car
How to remove a idle air control valve is windstar 2001
Idle Air Control Valve The Idle Air Control (IAC) valve is located on the air intake plenum.
Disconnect the battery ground cable.
Disconnect the Idle Air Control (IAC) electrical connector.
Remove the bolts and the IAC valve.
Discard the gasket.
To install:
Install a new gasket and position the IAC valve.
Torque the retaining bolts to 8 ft. lbs. (11 Nm).
Attach the electrical connector.
Reconnect the battery ground cable.
May 23, 2010 | 2001 Ford Windstar
Have charged the battery on my 1999mitsubishi mirage
you may connecting it wrongly , please check +ve and-ve both pole are to be fix with proper wire, if will do wrong it will blow fuse.
Jan 31, 2010 | 1997 Mitsubishi Mirage
I need to replace the heater a/c blower motor, how do I.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  3. Remove or disconnect the following:
    • Glove box assembly
    • Joint duct
    • Resistor
    • Blower fan and motor
    • Air changeover damper motor
    • Blower assembly
To install:
    • Blower assembly into duct
    • Air changeover damper motor and reconnect the electrical plug
    NOTE Lubricate the damper motor's slide contacts with multi-purpose grease
    • Blower fan and motor into the plenum and reconnect the electrical plug
    • Resistor on the joint duct
    • Joint duct to blower assembly
The blower motor is located on the right side of the heater housing.
  1. Disconnect battery.
  2. Remove the lower right under panel silencer duct.
  3. Remove the blower motor connector from resistor block.
  4. Remove the blower motor case retaining screws.
  5. Lower blower motor case from housing
  6. Remove the fan scroll from motor shaft.
  7. Remove the motor from motor case.
Blower motor (1)
To install:
  1. Install the in reverse order of removal.
Jan 19, 2010 | 2000 Dodge Stratus
I have the solenoid switch but i dont know how to change it. to a ford expidition 2000 5.4l
it will be located near the battery, follow the positive battery cable to the solenoid, disconnect the negative(black) battery cable first. remove the wires from the old solenoid, remove the bolts the hold the solenoid to the firewall or fender wall, install new solenoid into place then reconnect the wires. last reconnect negative battery cable & test repairs. make diagrams & mark wires as needed to avoid other problems
Oct 11, 2009 | 1999 Ford Expedition
Battery went bad installed new battery now service eng soon light on.plug obd2 scaner in tells me op er prob
try disconnecting the battery again for 2 hours & see if light stays out when you reconnect battery
Aug 14, 2009 | 2004 Ford Explorer
HOW DO YOU REPLACE A STARTER ON A 2003 DENALI
disconnect battery, disconnect wiring from starter & label, remove 2 bolts holding starter to engine. install new starter & bolts, reinstall wiring & reconnect battery
Jul 08, 2009 | 2005 GMC Yukon Xl Denali
Car Audio & Video Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
