Question about Uniden Cordless Phone
I recently brought Uniden DECT2035+2, i charged all handsets then tried connecting to phone line an all i get is a high pitched tone. have i done something wrong?
  • 56 Answers
Try connecting another phone and see if the same result. Have you tried calling the phone company?
Posted on Sep 15, 2011
Phone line repeatedly without reason goes to "in use" and will not go to a dial tone when receiver is picked up. the phone line does not do this when this att phone is not plugged into phone line
My first question would be, have you recently installed any after marked speakers, or radio into the car? You could have a grounded speaker wire, or connections not properly paired that could be causing the issues.
Jul 14, 2015 | Vtech AT&T CL82313 3 handset cordless...
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
Just brought the phone charge for 2 days phone reads handset out of range,
First check if the battery is properly connected/installed. It's possible for the connection to be loose. If this is your situation, recharge the handset again. Then try again.
Next make sure that the base has power (plugged into a live outlet). With a regular corded phone, make sure that the phone line is working. (Make sure that you get a dial tone.)
If the unit is new, you may want to contact Uniden. The battery may have degraded over time in a warehouse. If you bought the unit used, try a new battery.
I hope this helps.
Aug 14, 2011 | Uniden Lands Phones
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Phone sees call, but can't pick-up. Can't get d-tone to call out?
Just a suggestion (without knowing what troubleshooting steps from your manual you may have taken): Remove the batteries from the back of the handset and then put them back in after a few moments. My Panasonic KX-TGA8231B (DECT6.0) phones were acting up just like your Uniden is. All functions returned after this power interrupt "reset" with the batteries was done. Hope that helps. Good luck. - - -Gerry
Nov 30, 2009 | Uniden TRU9485 Cordless Phone
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
Can't make or recive calls
here is link to the instructions
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
first, test the actual socket using a good normal phone.
if no dial tone, get phone company to test the line.
if line ok, fully charge handset for 10 hours, if still faulty, follow the procedure to de-register and re-register your handset with the base unit.
Jan 17, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
62 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
