Question about Zanussi Washing Machines
Doesn't take water in and makes a weird noise
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Posted on Mar 19, 2011
My PixiePlus Singer is making a weird noise and doesn't sew!
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or loose
threads
if these suggestions don't help, then it would be a good idea
to take the machine to a sewing machine shop to be serviced
Jul 29, 2012 | Singer Sewing Machines
99 kia sportage 4wd doesn't work so i install the manual warn hubs on. car still doesn't work in 4wd mode. But when i shift it down to 4wd mode now it makes a weird noise from back bottom of car,...
dont worry about vac hoses as they are redundant with manual lock. i changed to manual and all fine so definately back differential or transfer case
Aug 10, 2011 | 1999 Kia Sportage
My jenn air fridge is making a weird buzzing humming noise, lasts about 5 seconds, happens about every 5 minutes or so. The sound is coming from the bottom of the fridge. Any idea why?
Does this have an icemaker and if so is it working correctly? That sounds like the sort of sound an icemaker water solenoid would make. A compressor could make the noise, but not usually that frequently. An icemaker that isn't hooked up but is calling for water may.
Dec 01, 2009 | Dryers
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Won't Spin the water out...
Hiya WRock04... would be nice to have make and model.. otherwise.. look to replacing the brushes in the motor if the machine has done relatively little work... 3-5 yrs in some cases... otherwise a new motor unfortunately may be required.. specially if you can smell burning!!
regards Faggly
Mar 19, 2008 | GE WBSR3140DW Top Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
