Question about GE 32GT740 32" TV
GE 32GT740 32" TV circuit map
As problem happens on EPROM IC chip, where I get a diagram for part assignments on TV circuit borad?
Thank you!
  • 30 Answers
My best answer is check with your local TV shop for any service manuals. Most TV companies do not sell parts or information to consumers. This is true for RCA/GE as well. You can google search your TV model and see if you can find any info.
In google type GE32GT40 service manuals.
Hope this helps!
Chriss TV
Posted on Aug 02, 2008
GE 25GT270 TV had a jumpy picture for a short time, then TV shut down. Afterward, smelled a burning smell. What happened and can I fix it?
Check its vertical output section circuit for damaged component/s. Check the vertical output IC.
Feb 19, 2013 | GE 25GT270 TV
PICTURE FLIPPING HORIZONTAL - OLDER TVS HAD A HORIZONTAL OR VERTICAL HOLD BUTTON - WHAT HAPPENED TO THOSE BUTTONS?!?
U talking about way back in the 40 and 50.From the 60 on tv all use intergrated circuit board.Mostly ICS chips now,no more tubes and analog parts.The problems ur tv have is the Horizontal IC chip is dead.
Sep 09, 2010 | Philips Magnavox 27MS343S 27" TV
T.V. SHUTS OFF - SCREEN GREEN WHEN TURNED BACK ON!!!!
is it a tv or rear-projector? does it brings out the sound?
on a tv it could be the chromatisation IC that is defectiven when it goes blank. why? because of a power surge in the electrical net the tv got too much voltage to take.
try to desoldeer the EPROM IC and power on the set. does this make the set goes normal blue screen? if YES,you can order a new EPROM IC.
succes and enjoy
Jul 17, 2010 | Sharp 13VT-R100 13 in. TV/VCR Combo
Have a GE 32GT740 32" TV.....How can I adjust the Verticle? I can only see part of the ESPN trailer line at the bottom of the screen.
the vertical deflection circuit of your tv has a problem.first try to replace the vertical ic..this ic can be found near the plyback or horizontal section It is a lenear ic with heatsinc..if nothing happens after replacing the ic ,,replace all the polarized capacitor near the ic and resolder the components at the vertical section...good luck please rate my help..
Jun 03, 2010 | GE 32GT740 32" TV
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
TV Help!!
Yes , this sounds like the EPROM IC is failing or the crystal that keeps the frequency on the IC needs to be replaced , or even the buttons on the tv could be warped by the heat of the tv( if it is the buttons , then removing the control board from the plastic buttons will stop the random cycle and may make it so you can turn on the tv , but if not then it is the EPROM IC or crystal)
to check and see if the chip is messing up , hold down the menu button on the tv or vol up down and see if it stops cycling thru the video inputs
electech
Nov 21, 2008 | Televison & Video
No soounding in my GE 32GT740 32" TV
Yes it is called an EEPROM IC chip that needs to be replaced. Very comon to fail on these types of sets. GE owned RCA back the 1990's now funai owns both along with magnavox and parts may be hard to get.
Jul 27, 2008 | GE 32GT740 32" TV
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Rca 24V511T
take123, problem is with vertical circuit not eprom, could be bad capacitor supporting the IC or the IC itself is bad, that type of problem needs a tech because once it`s fixed you will probably have to go into the service menu and re-adjust the vertical positioning, this of course will require the info in the service manual which you can`t easily obtain, questions? e-mail me back, BMW Rider
Nov 30, 2007 | RCA F36650 36" TV
GE 32GT740 32" TV Logo
256 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
