Question about Microwave Ovens
I need flange and filter adaptor kit to connect extractor EDIP 638.1 E to ducting in the wall. Also rubber seal for hob model EKI 607.2M
  • 56 Answers
Lowes has them. Or Home Depot
Posted on Sep 15, 2011
I have a new ranghood with a 150mm duct, how can I connect this to the existing 125mm duct in my kitchen
If this is a circular duct there are 125 to 150 mm adaptors / reducers available at most home DIY stores.
http://www.fastlec.co.uk/circular-spigot-adapter-150mm-to-125mm-duct-reducer-p-1720.html
larger image:
http://www.fastlec.co.uk/images/ventilation/domus/118.jpg
This should be what you need. It would be a matter of finding your local source for the reducer / adapter.
Thanks for choosing FixYa,
Kelly
Aug 05, 2011 | Microwave Ovens
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 10, 2011 | Frigidaire FMV156DC Microwave Oven
What is the minimum distance from the top of oven to the bottom of microwave
It depends greatly on the ventilation but if you use 20" above the hob, as a good starting point. If you have extractor fans, maybe less. Don't forget the grill gets hot on top of the oven but there should be at least 10" clearence between the grill top and the microwave base, more if it is gas!
Dec 21, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
I Have a GE Micro JVM2070. When I boil water on the stove the water vapor shorts out the Micro. It then turns it self on or doesn't work at all. If I unplug it it might work in a few days.
One would think that you would have the sense to use the extractor that is above your stove and under your microwave, would you use a laptop in a sauna!!! no wonder the thing is shorting out. Contact the person who fitted the microwave. always use the extractor when you boil things on the hob.
I live in England it is illegal to have a microwave above a hob for this exact reason. America will catch up eventually with building regulations!!
Nov 05, 2009 | GE JVM2070 Microwave Oven
Need assistance installing a JVM1660BB range microwave oven. How do I attach the sleave to the duct to the microwave, while mounting the Microwave on the wall. Thanks for the specs on the microwave oven....
From page 14 of the installation instructions online here:
"Extend the house duct down to connect to
the exhaust adaptor.
"Seal exhaust duct joints using duct tape."
Jun 06, 2009 | GE JVM1660 Microwave Oven
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
Installation of GE Microwave Oven
We have changed out a GE for another same brand, newer model. You will need two people to make the change-one of the two must be strong enough to support the unit after you remove the 3 bolts that hold it into the cabinet above. You will see these screws in the bottom shelf of the cabinet above your unit. A driver drill w/ the socket attachment to fit these "screws" would make it go faster. You'll need a step stool or a step ladder to get above the unit. There is a power cord that plugs into an outlet-make sure you have unplugged this before starting.While one is supporting the unit, the other is unscrewing the three bolts, When screws are out, the person on the ladder should come down and help w/ the unit removal. The unit is tipped forward to release it from the wall, as it is hooked into a bracket affixed to the wall. When you tip it forward, both of you should be prepared to lift it off the bracket. It helps to have the way cleared and a table or countertop ready on which to set it. BTW, My microwave installer did not use the flange provided to seal the vent around the cutout in the lower shelf of the upper cabinet. Removing ours, I can see why, there is no way to get the unit lined up w/ the flange and the duct and still tip it into the provided cut out. We bought metal sticky duct tape to seal it, and used the opportunity to reseal the above cut outs as well. I think some cabinets are constructed around the microwave installation, and if so, you could use the existing flange set up. When you are ready to put in the new one, do it in reverse, but schedule some clean up time in between, the grease finds a way of eluding all systems and you'll want to 409 it before putting in your new one. If this is too mu8ch for you, ask an installer or a neighbor to help-it doesn't require an electrician. You might want to ok into what GE is doing these days so your aren't dissappointed w/ the new unit after such a successful run with your first purchase.
Jul 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
