Question about Hyundai Car Audio & Video
After disconnecting the battery on my 2004 Hyundai Santa Fe the radio is now showing 1CDE and I do not have the code to reset it. The serial number is (01) 18809121790017(21)04063875 Thank you
  • quokka Sep 15, 2011
    Hi Yes your correct, I already did that and they did reset it for free. I dont know how to remove the question?
  • 56 Answers
Take it to Hundai. They will reset it for free.
Posted on Sep 15, 2011
How to change a misfire sensor on a 2004 Hyundai Santa Fe
misfire sensor is next to the thermostat housing held on with two small fasteners
Jul 31, 2014 | 2004 Hyundai Santa Fe
How to replace starter on 2011 hyundai santa fe
To Replace the starter motor of the 2011 Santa fe is simple on nearly every make and model of passenger vehicle. The battery is disconnected to prevent electrical shock or damage to sensitive electronic components, and then the starter motor is disconnected from all electrical connectors. Once disconnected, the starter, and any shims used, are removed from the vehicle with only a couple of bolts, and replaced in the opposite order of operations. The electrical connections must be placed on the correct terminals, also known as "posts", and the replacement starter should have the same number of posts as the original.
Or you can check this video out which will guide you to Replace starter for 2010 Hyundai Santa Fe, have a look
Jun 25, 2014 | 2004 Hyundai Santa Fe
2002 hyundai santa fe, Speedometer fails intermittently.
Well maybe Check the fuses, If that does not work then when you can disconnect the battery for 24 Hours so the computer can reset. make sure all your ground cables are bolted tightly. hope it helps
Jan 18, 2014 | 2004 Hyundai Santa Fe
Won't play just says 1CDE on screen
Some cars if you disconnect the battery more then 30 secs you got to put a code in the radio to play it again. They probably have the code written in your Car Manual if not you got to take the radio out and find the serial no# on the back of the radio. Write it down tell the dealer it and they should tell you the code.
Mar 27, 2010 | 2007 Hyundai Accent GS Hatchback
How do I reset the radio
look for 4 digit security code in owners/maintenance books enter into radio.you have 3 attempts before lockout. if this occurs disconnect battery again
Mar 09, 2010 | 2004 Hyundai Santa Fe
My sister ran just one tankful of E85 gas through her Santa Fe and there was an indicator light that came on. Will it go off once she runs some unleaded gas back through it or will she have to take it to a...
It could go off after running some unleaded gas such as a couple gallons of 'premium unleaded' through it. But you should also try to reset it. To do this follow these simple steps:
1. Write down the radio code of the car.
2. Disconnect the battery negative terminal for about twenty minutes. Then reconnect back the battery negative terminal.
3. The indicator light should be 'off'.
Dec 21, 2009 | 2004 Hyundai Santa Fe
How do you reset the brain on a hyundai santa fe suv
You can simply disconnect the battery. Wait a while and connect them again.
Nov 23, 2009 | 2004 Hyundai Santa Fe
Steps to remove radio
  • Step 1:Disconnect the negative cable from the battery terminal. Position the cable to is doesn't come in contact with any metal parts.
  • Step 2:Pull out the ashtray and remove the two screws that connect the bezel around the radio. Pull off the climate control knobs and remove the two screws at the top of the bezel trim.
  • Step 3:Remove the trim and disconnecting any wires. Not all models will have connecting wires on the trim.
  • Step 4:Locate the two screws, one on each side of the Hyundai Santa Fe stereo, and pull the head unit out of the dash. Disconnect the wires behind the radio.
  • Thanks for using FixYa - a FixYa rating is appreciated!!
    Feb 20, 2009 | 2004 Hyundai Santa Fe
    Car Audio & Video Logo
    714 people viewed this question
    Top Hyundai Car Audio & Video Experts
    David Burbee
    David Burbee
    Jude24
    Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
