Question about Samsung Refrigerators
Need to turn off the door alarm on my srl551dp. fridge is working fine but refridgerator temp stays on 9 degress
  • Anonymous Aug 27, 2015
    I have exactly the same problem!!!! Its driving us mad!!!! Can you help? What did you do?
  • shenanw123 Jan 20, 2018
    Sorry this was so late. I changed my chat name and obviously havnt logged into this 1 for along time. Was it the alarm or it was staying at 9 degrees. I realise you would of fixed or replaced by now
    Problem Solver:
  • 8 Answers
Whats the serial number of the fridge Its on the top of the sticker in the fridge and on the sticker on the outer left side of the freezer
Posted on Mar 22, 2011
Need to turn off the alarm on my Samsung SRL551DP FRIDGE it refuses to change from 9 degrees and alarm keeps going off
You may be having cooling issues due to a defrost problem and the alarm is warning you of the problems
Appliance 911 Sea Breeze
Aug 27, 2015 | Samsung Refrigerators
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
The temp alarm is sounding
Auto defrost system not working properly
staying in defrost to long,door gasket leak
compressor overheat,controls turned up max
all above can cause your problem
even cloged defrost drain
Apr 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Refridge compartment warm not cooling
I hope the following helps.
Turn the entire control system off for at least two minutes. This will give the computer module time to reset to factory default. Turn of to desired level after two minutes. Should that not work then there is a problem with the timing relay. They relay is brand specific, meaning take the model number to the parts store for a new one.
Your compressor should be fine. You may also remove the power by unplugging the refrig.
CAUTION: Before removing the relay the power to the fridge must be OFF. Failure to have it in the off postion can cause the new relay to short which can lead to mkore problems. So UNPLUG the fridge, remove the relay, replace the relay and then plug fridge back min. Set control to desired cooling level and wait a couple hours. That should do the trick.. IF not then there is an issue with the processor module.
Jan 04, 2009 | Refrigerators
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door alarm goes off every 4 minutes (plays music}
i'm got a Samsung RSH1DTMH side by side and its doing the same thing. it seems to be once a week. Last night i opened it to get a drink about 23:30, and then dealt with the alarm, reset 10-15 minutes until 01:30 and then said "F-it" at that point i didnt care if i lost everything i n it. it stayed at -25 in freezer all night, +7 (set to +3) in fridge all lights on, normal operation noises. WHAT THE F GIVES SAMSUNGGGGGGG
Oct 12, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
490 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
