Have moved into new house with unit but no instructions would like to know how to use the control properly and also what fliters to clean a detailed description on how to operate these two issues would be great
  • chrissoliney Mar 19, 2011
    The unit is a Daiken Inverter model number FTXS71GVMA serial number E009189
  • 19,396 Answers
Hi.
Can you please provide the complete model of the appliance in question, so that we can help providing the specific documentation?
Many thanks.
Ginko.
Posted on Mar 19, 2011
No steam or water even coming out, its just quiet except brushes moving
David, the brushes on the motor may be burned out and the conduction process has been compromised. In short the motor is bound up and won't turn. This can happen if surface debris collect on parts of the motor. Do not turn it on for long and let the unit get warm as it will eventually break down permanently.
If you need a manual, go the company web site and seek that from customer services.
Mar 10, 2014 | Bissell 46B4 Stick Steam Cleaner
Pause button not working
If all other buttons work properly, and only Pause button doesn't, it might be due to the internal fault to the remote control. Open it and clean it. To know how to check and clean a remote control, this site will give you more details.
Dec 28, 2012 | JVC New Original RM-STHS3J Remote Control
We are moving to a new house (just three miles). How critical are the transport instructions for the He2 Plus washer?
The mount system is important to stabilize the tub during transport, if your careful you can move this without them. To prevent damage, you can remove the top, pack the unit with blankets to prevent banging around, and damage to control panel inside. Just be careful and this can be done without damage to the unit.
Good Luck
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Door won't open after self cleaning.
    it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
    Dec 31, 2007 | Ovens
    Microwave not working
    Found this Samsung model problem in the Welbilt section but will try to help just the same. Hope you find it.
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    You can download your owner's manual here:
    http://downloadcenter.samsung.com/content/UM/200303/20030324114252562_DE68_00064C-02.pdf
    I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
    Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
    Otherwise, the spray can get into the controls and lock it up or make it act odd.
    If it does not dry out over time, it may need to be manually dried or blown out.
    The keypad may be damaged or worn out, or control unit may be damaged.
    You can order a new keypad (membrane switch) here:
    http://www.samsungparts.com/search/search.asp
    Please write back with more details if you need further help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Nov 29, 2007 | Welbilt MR622W Microwave Oven
    Heating & Cooling Logo
    70 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
