Question about AEG Dishwashers
Newdishwasher installed October. Seems to be making "put putting sounds" clicking noises. Programme just not moving on. Filters clean. Shouldnt be kinks anywhere, as the machine has worked great since installation, and hasnt been moved atall.. Machine is AEG Favorit 35020 V1
SOURCE: My AEG favorit sensorlogic turbo
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG Favorit 6040 Dishwasher has continuous tone
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Posted on Jan 20, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
  • 20 Answers
SOURCE: I need an manual in english for the AEG Favorit
try here. http://www.serviceforce.co.uk/pdf_search.asp
Posted on Jan 21, 2010
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Makes clicking noise.
It sounds like it's having trouble reading the disk. Check the disk to be sure it's free of fingerprints and grease. If it's clean then the lens that scans the disk is broken and should be replaced.
Mar 13, 2010 | Video Game Consoles & Games
Loud Whining Noise from Motherboard on Startup
Whining noise is something in motion or moving.Does the graphics card have a onboard fan?Is it clean and free moving.
How about the processor fan? clean,free from wires or anything hitting it.?
Disconnect hard drive and see if you get the sound.
Jan 18, 2010 | Abit IP35P Motherboard
01' F-250 SD noise in trans
have the transmission rebuilt sounds as if drive gears are wore out.
Oct 09, 2008 | 2000 Ford F250 Super Duty Crew Cabs
My ACER Aspire 9301AWSMi has run out of space on its hard disk. When I checked, the ACER C drive is full, but the ACER D drive ir empty with 33 gb of free space but I don't know how to access it, as I...
you just right click on the d drive and select explore or double click it, there won't be anything in the drive apart from maybe a system back up file.
when in there make a new folder called programme files
If you have a lot of programmes installed on your c drive, then uninsatl them and reinstall again, but when the option comes up to install in a specific folder choose 'D' drive then choose programme files folder, the programme will then be installed there, but will still put an icon on your desktop as normal.
you can also transfer any video or music to the d drive, just make a folder in the d drive called music and video, select your music you wish to move select 'Cut' then open the folder on the 'D' drive and select paste.
Also run this free programme to clear your system up
http://www.filehippo.com/download_ccleaner/
Aug 17, 2008 | Acer Computers & Internet
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Clicking noises
check to make sure the wires going to the main fan are not hitting the blades.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Clicking noise
I had the same problem.
We could put one cell in and it worked with out clicking. Putting the second one in solo however, it was clicking.
I looked closely at the second cell and discovered that two of the vanes on the side with the wires were bent at about 20 degrees off. Adjusting this and reinserting reduced the clicking but not completely. I pulled the cell and focused on the same two vanes and discover one was also bent in, gently pulled it back and no more clicking!
My wife had cleaned the filters and my 6 yr old and 4 year old had to help. I wonder how they got bent?!
We have had the cleaner for about 6 yrs and no problems until this last cleaning.
Be very careful in adjusting the cells. Aluminum does not like being bent and weakens each time it is moved, like pulling a tab off a beer can (of course the cells are made from much thicker and higher grade aluminum)!
Jan 23, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Dishwashers Logo
35 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
