Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Test Points I have an almost dead P50HDM, when off the panel light is yellow when turned on a green light no sound or screen activity. I am an old retired PC, TV Tech and Plasma in new to me but noticed all the test points thru out the system but can't find any specs on the Internet to determine failed board or boards. Can anyone give me some insight to my request?
  • Gary Aug 04, 2008
    Thanks for the non answer to the question. After spending many unnecessary hours searching Goggle for my above simple request, I find that a majority of us have the same problem with this company that "Cost.o" helped get this company into HDTV business back in 2004 and now think it's time for a "CLASS ACTION LAW SUITE" and believe you me this problem will be resolved faster than you can surf the net! Now with the same reworded feedback that we have gotten on the forums I will continue to the higher level.
I was in a bit of a hurry and unable to give you a detailed answer so let me be very specific.
First, if you purchased the Vizio P50HDM from Costco they are aware of the problem and will either fix it at their cost or give you a brand new 50 Inch Vizio Plasma for free like they did for me. You simply need to call their Concierge service at 1-866-861-0450 and have the dead TV in front of you when you call. They will diagnose it over the phone with you and send out a techie. If the panels were busted during the Pop they will give you a new TV. By the way class action suits only make lawyers rich.
Second, if you didn't buy the TV at Costco here is your procedure: Replace the Z Sustainer Board, Part # 6871QZH044B and replace the Y Sustainter Board, Part # 6871QYH039B at the same time. If you replace one and not the other the bad one will end up shorting the good one and you’ll lose your picture within a week. You can do this work yourself by unplugging the unit and placing it face down on carpet (put down a soft blanket to protect the screen) and unscrewing the back of the unit (a power screw driver works great for this job because there are a few screws involved). The cheapest place to buy these two parts are: , or, or There are two additional Y Sustainer supporting Boards called the Upper and Lower Y Boards in the P50HDM that can also be replaced at the time of the Z and Y Replacement. There part numbers are: 6871QDH088A and 6871QDH089A. Although some techies prefer to replace them at the same time as the main Z & Y Boards they probably weren’t the cause of the problem and most likely don’t need to be replaced. However, if you decide to replace them along with the Z & Y then it’s additional insurance that it won’t happen again, plus these boards are actually pretty cheap unlike the Z and Y which are a bit more expensive. It’s also popular to add two additional CPU fans to the unit for additional cooling. Apparently the POD (Pop of Death) has something to do with the main Z and Y overheating.
I hope this helps.
Posted on Aug 04, 2008
    Problem Solver:
  • 8 Answers
If you bought it at costco call their Conciere service and they will send out a techie to repair it at their cost, even if it's out of warranty (so long as you kept your membership current). If you didn't get it at costco go to google and put it P50HDM Pop and there are plenty of answers to your problems. I've even posted a few myself.
Posted on Aug 02, 2008
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi, I have a Vizio P50HDM
For your Zenith P42W34D TV. The problem cause the a bad Y drive board. Replace the board will fix it.
Hope this will help.
Jan 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
Vizio 50" P50hdm Audio with No Video
when tv is on horz trans is damge
Apr 10, 2008 | Televison & Video
On and off and on again
You have a power supply problem, it is in standby . Replace powersupply board or fix it.
Nov 26, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
445 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
