Question about Lenovo IdeaPad S10-2 (29577NU) Netbook
There is no display on the screen. This is the second time around.
    Guru:
  • 406 Answers
Since its the second time around I suggest you call the lenovo tech support, 1877-453-6686 then choose option 2. Have it covered by the warranty.
Posted on Mar 19, 2011
Dell optiplex 170l screen problems on shut down
Disconnect the monitor cable from the computer and power on the monitor. It has a built-in diagnostic program. If you see color bars floating around the screen then you monitor is O.K.
Jul 24, 2012 | Dell Computers & Internet
The screen is going black like its in sleep mode when i open it up
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
Crcked screen
dude thats it mate game over
Oct 13, 2009 | Samsung SGH-A877 Impression Cell Phone
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Dell model No. 1504FP will turn on for 3 sec then off
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
May 12, 2009 | Dell 1503FP 15" LCD Monitor
I-mate sp5m no display
pls try to update ur system software other wisedo the following
first switch off ur phone and then do following
here it is
1. Press and hold soft1 and soft2 keys.
2. Press and hold power button for around 1 to 1.5 seconds. Release power button. Keep hold soft1 and soft2 keys.
3. Later, screen shoould show instructions to ask user to press '0' key to reset to factory default.
4. Press '0' within the timeout period, which is only several seconds only.
5. If no instruction is shown on the screen, repeat steps 1 to 4.
The timing is sensitive.
but you will loose all data.
pls rate me fixya if i have fixed what u needed
Jan 30, 2009 | i-mate SP5m Smartphone
PC monitor not lighting up for around 10 mins
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Apr 08, 2008 | Computers & Internet
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Jun 14, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Lenovo IdeaPad S10-2 (29577NU) Netbook Logo
61 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
