Question about Kenmore Elite 45986 Front Load Washer
What does an error code 11 mean? I have a Kenmore Elite model 110 45996 4000. thank you - Susan
    Brigadier General:
  • 6,277 Answers
For Kenmore (manufactured by Whirlpool) washers F11 decodes as 'communications error' (with the controller). That is sometimes caused by bad contact between the PCB and the cables/plugs attached to it.
Unfortunately I suspect you will need to call an engineer/technician in to identify the cause;-0(
Sorry and good luck,
John C
Posted on Mar 19, 2011
  • Kenmore Master
  • 2,699 Answers
You can check the wires for loose connections but most likely you'll have to change out the ccu or the mcu,some people say change both of them but i don't agree,the ccu or computer control unit i've found is usually the problem,i just changed out two of them but like i say it could also be the mcu motor control unit,both parts are expensive so if i were you i'd change one out and then the other if need be,there's no real way on telling what part it is,welcome to the computer world and this is why some say to change both parts out so you'll know the problem will be fixed the first time.i had a feeling it was the ccu because before the code came up the ccu was clicking alot,the ccu and mcu communicate to each other but it just sounded like the ccu couldn't answer back,it was just clicking away and then the code came up.i'm gonna send a site to you,they give you one year to either keep the part or send it back even if it's electronic,alot of companies will not do this,so you can order both the ccu and mcu,install the ccu or computer control unit,this is like the brain of the machine,if it solves the problem you know you got it and you can send the other part back,if it doesn't solve the problem you can install the mcu motor control unit and send the other part back and you fixed it yourself and alot cheaper than calling in a repair guy,just make a wire diagram or mark the connectors and you'll be fine,i'm gonna look up the site and i'll send it to you.hope this helps.
Posted on Mar 24, 2011
  • Sal De Mar 24, 2011
    Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes | Washer Repair | Fixitnow.com Samurai Appliance Repair Man ....................copy and paste this,everything before the periods and this should help you out,good luck,let me know how you make out.
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine
    www.shopyourway.com > Manage My Life > Questions
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
    faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
    Jan 22, 2015 | Kenmore Refrigerators
    What does F-11 error code mean on my Kenmore HE 4t front loader washer?
    I believe it means motor control unit failure. Make sure nothing is plugged into same circuit unplug unit for 10 min. and try again . If it still does not work you will need a tech
    Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
    Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
    wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
    Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he14. What is the f14 error?
    EEPROM Error
    The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
    If there is an error reading this data, it will cuse this error.
    A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
    Check CCU
    So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite Washing machine error codes
    I am getting F35 error code. What is the problem?
    Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    270 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
